Seafile Pro Docker - Elasticsearch Authentication Error
I did a test install of Seafile PE 10.0.11 using the provided docker-compose.yml and editing only volume paths & passwords. Running docker as root. Everything seems to work except elasticsearch. On the main screen I get no search results. When I expand the search box, I see a red “Internal Server Error” message under the search box.
Per another post, I confirmed in my seafevents.conf
[INDEX FILES]
external_es_server = true
es_host = elasticsearch
es_port = 9200
enabled = true
interval = 10m
Per that same post, I tried running
docker exec -it seafile /opt/seafile/seafile-server-latest/pro/pro.py search --update
The last msg I get from that command is:
[ERROR] seafes:158 start_index_local: Index process init error: AuthenticationException(401, 'None').
So… then I tried setting credentials as environment variables for elasticsearch in the docker-compose.yml and, per the docs, adding the following to my seafevents.conf.
## From 9.0.7 pro, Seafile supports connecting to Elasticsearch through username and password, you need to configure username and password for the Elasticsearch server
username = elastic           # username to connect to Elasticsearch
password = elastic_password  # password to connect to Elasticsearch
But, that didn’t help. I can manually curl -u with the credentials I created, but Seafile still returns the same error.
Then I tried disabling elasticsearch authentication completely by adding the following to the docker-compose.yml:
- xpack.security.enabled=false
This worked. I no longer see the Authentication error when running pro.py search --update and search works in the GUI.
It seems to me Seafile is, out-of-the-box, trying to send some incorrect credentials to elasticsearch or Seafile is not sending credentials elasticsearch is expecting.
Anyone see this before? Or, is running elasticsearch with security disabled reasonable?
Thanks!
We cannot reproduce the problem with the docker image. Maybe there is something wrong in your steps.
Without password is reasonable, if you restrict the ES to be accessible only locally or specific IP address.
I recently setup seafile pro with docker and also same as you I had to modify elasticsearch.yml
with
However the log error I was seeing were completely different than your
I was seeing
“WARN”, “message”:“received plaintext http traffic on an https channel, closing connection
I made a post about my issue here:
ht t p s ://forum.seafile.com/t/seafile-server-pro-edition-w-docker-default-docker-compose-yml-wont-connect-to-elasticsearch/18948
Were you able to find how to keep xpack.security.enabled=true and to get seafile working with elasticsearch?
