I noticed that on 7.1.5 version with seaDrive 2.05.
There were also some issues regarding long file path or unwilled characters at the end of the path.
Is it solved ?
since upgrading to 7.1.7 pro (from 7.0.11 pro) elastic search is not running anymore.
I see the following line repeatedly in the logs:
index.log
08/29/2020 13:24:06 [ERROR] seafes:158 start_index_local: Index process init error: ConnectionError(<urllib3.connection.HTTPConnection object at 0x7f1ad013fba8>: Failed to establish a new connection: [Errno 111] Connection refused) caused by: NewConnectionError(<urllib3.connection.HTTPConnection object at 0x7f1ad013fba8>: Failed to establish a new connection: [Errno 111] Connection refused).
controller.log:
[08/29/20 13:32:47] seafile-controller.c(169): bad pidfile format: /srv/seafile/pids/elasticsearch.pid
[08/29/20 13:32:47] seafile-controller.c(588): failed to read pidfile /srv/seafile/pids/elasticsearch.pid: Success
the pid file is empty.
updating the index manually yields the following error:
./pro.py search --update
Since seafile-pro 7.0.0, we have upgraded Elasticsearch to 5.6. As Elasticsearch 5.6 relies on the Java 8 environment and can’t run with root, you need to run Seafile with a non-root user and upgrade the Java version.
yes, thank you, I checked the upgrade instructions. we are running seafile under the user seafile since a long time. the default version of java in debian 10 ist openjdk-11. anyhow, these were important point when upgrading to 7.0, not from 7.0 to 7.1. elasticsearch was running fine under 7.0.11.
