Files count in System Admin -> Libraries is always 0. Can anyone confirm this in 7.1.1?
Confirmed.
Then I guess it is a bug. @daniel.pan
I tried to use seafdav with Seafile 7.1.1 on CentOS 8 but did not get it working up to now.
Missing python libraries were installed:
sudo su - seafile
pip3 install wsgidav --user
pip3 install --upgrade six>=1.13.0 --user
Log file /opt/seafile/logs/controller.log shows same error message every 10 seconds:
[01/26/20 23:17:54] seafile-controller.c(412): pid file /opt/seafile/pids/seafdav.pid does not exist
[01/26/20 23:17:54] seafile-controller.c(444): seafdav need restart…
[01/26/20 23:17:54] seafile-controller.c(79): spawn_process: /usr/bin/python3 -m wsgidav.server.server_cli --server gunicorn --root / --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host 0.0.0.0[01/26/20 23:17:54] seafile-controller.c(94): spawned /usr/bin/python3, pid 2097`
No seafdav.pid file is created. Looks like process is started and terminates immediately.
Manual start of wsgidav is not possible. I get the following error message:
usage: wsgidav [-h] [-p PORT] [-H HOST] [-r ROOT_PATH]
[–auth {anonymous,nt,pam-login}]
[–server {paste,gevent,cheroot,cherrypy,ext-wsgiutils,flup-fcgi,flup-fcgi_fork,wsgiref}]
[–ssl-adapter {builtin,pyopenssl}] [-v | -q]
[-c CONFIG_FILE | --no-config] [-V]
wsgidav: error: argument --server: invalid choice: ‘gunicorn’ (choose from ‘paste’, ‘gevent’, ‘cheroot’, ‘cherrypy’, ‘ext-wsgiutils’, ‘flup-fcgi’, ‘flup-fcgi_fork’, ‘wsgiref’)
wsgidav --version
3.0.2
How can I get webdav working?
Hello, may I know when PRO version will be available?
Thanks
We will have a beta release in the next week.
I mean the pro edition.
Any info for CE then? Are these confirmed issues (or config problems)? If yes, are they also present in the upcoming Pro Beta and if not, why don’t you test the fix in CE as usual?
We will release a new CE version in the next week.
Actually, there are no big issues with the current 7.1.1 CE.
How did you get so far?
I’m still at
ModuleNotFoundError: No module named ‘captcha’
on CentOS 8 after yum update
Thanks!
Today I have tested Seafile Pro 7.1 for quite some hours and can not find any issues yet.
The upgrade process works like a charm and damn… it is fast. At least this is my subjective view.
I thought the PDF online viewer should be improved in 8.0 later this year (see Roadmap). But the zoom-in & zoom-out functionality is already implemented in 7.1. At the moment mobile users (at least iOS) have to use the “+”/"-"-Buttons to zoom otherwise it is still blurry. Approximately 65-75% of our users access Seafile via Smartphone/Tablet. It would be nice if users could zoom with touch gestures.
At this point I just want to thank the team at Seafile Ltd. for developing this great software.
In addition to suggestions and criticism, I think there should be recognition in some places.
Did you try sudo pip3 install django-simple-captcha ?
As described I was not able to start seafdav and get seafile webdav feature running on CentOS 8? Are you able to run it?
For all those that missed it:
Seafile Server Professional Edition 7.1.0 (beta) is out.
You find the changelog and update instructions here.
It is strange to me… WebDAV worked quite fine yesterday. Today I added multiple storage backends (only different local storage pools), restart seafile&seahub and WebDAV is broken. I got this error:
/usr/bin/python3: Error while finding module specification for ‘seafevents.main’ (ModuleNotFoundError: No module named ‘seafevents’)
It is reproduceable every time if you:
- Comment out all related parts in seafile.conf & seahub_settings.py (in my case:)
seafile.conf:
#[storage]
#enable_storage_classes = true
#storage_classes_file = /opt/seafile/conf/storage_classes.json
seahub_settings.py
#ENABLE_STORAGE_CLASSES = True
#STORAGE_CLASS_MAPPING_POLICY = ‘USER_SELECT’
- Restart seafile & seahub → seafdav.pid is there & WebDAV is working
- Undo all changes and restart seafile & seahub → no WebDAV and the known error message.
I am testing on Debian Buster. @daniel.pan I think this is a bug.
Edit: I copied in the wrong error message. Not it is corrected.
@k4zz You issue is caused by manually installation of wsgidav. You should use the modified version of wsgidav included in seafile package. You can try to uninstall wsgidav from your system.
I experienced an issue upgrading from Seafile Pro Ubuntu 7.0.13 to 7.1.0 beta. The problem was due to a ‘%’ in my MySQL password, which caused problems with the db_update_helper.py and seahub.sh scripts. I changed the password in all of my config files (to remove the ‘%’), as well as in MySQL, after which the upgrade script worked fine. After upgrading, I changed my password back and seahub.sh would not start. It works perfectly using a password without a ‘%’. I’m not sure why this causes problems, but I wanted to report the issue. As always, keep up the good work and thanks for an excellent product!
that did the trick!
Thank you!
@Jonathan: Thanks for your answer! I tried with a fresh server and fresh seafile installation on CentOS8 but still was not able to use seafdav!
First I got an error message about missing _sha1 module:
/opt/seafile/seafile-server-latest/seahub.sh start-fastcgi
File “/opt/seafile/seafile-server-7.1.1/seahub/seahub/repo_api_tokens/models.py”, line 1, in
from _sha1 import sha1
ModuleNotFoundError: No module named ‘_sha1’
I fixed it by replacing first line of file “/opt/seafile/seafile-server-7.1.1/seahub/seahub/repo_api_tokens/models.py” “from _sha1 import sha1” with “import hashlib” as discussed here Failed to install hashlib, python 3, debian - Stack Overflow
Then I enabled webdav in conf/seafdav.conf and got same error message in log file logs/controller.log every 10 seconds:
[02/27/20 22:49:58] seafile-controller.c(412): pid file /opt/seafile/pids/seafdav.pid does not exist
[02/27/20 22:49:58] seafile-controller.c(444): seafdav need restart…
[02/27/20 22:49:58] seafile-controller.c(79): spawn_process: /usr/bin/python3 -m wsgidav.server.server_cli --server gunicorn --root / --log-file /opt/seafile/logs/seafdav.log --pid /opt/seafile/pids/seafdav.pid --port 8080 --host 0.0.0.0
[02/27/20 22:49:58] seafile-controller.c(94): spawned /usr/bin/python3, pid 3441
If I execute command in a shell by hand
I get error message
/usr/bin/python3: Error while finding module specification for ‘wsgidav.server.server_cli’ (ModuleNotFoundError: No module named ‘wsgidav’)
That’s why I tried to install module wsgidav by hand. (pip3 install wsgidav --user).
How can I install correct module wsgidav? Or why is module wsgidav shipped together with seafile (/opt/seafile/seafile-server-7.1.1/seahub/thirdpart/wsgidav) not found?
