Seafile Server Pro 7.1.8 - Centos 8 - Problem with the SSL CA cert (path? access rights?)
Having an issue with setting up Wasabi S3 as backend on Seafile Pro 7.1.8. getting the error libcurl failed to head fs-commit-objects … Problem with the SSL CA cert (path? access rights?)
Everything works when use https set to false, and error appears when use https set to true.
Would like to be able to run with https.
Thanks in advace.
Best regards,
