I’ve read this on HP Servers documentation
Performance Tuning using Change Notify
This section describes performance tuning using the Change Notify feature and internationalization.
NOTE: Starting with the Samba 3.0.25 version, the Change Notify Timeout feature is deprecated.
The Change Notify Timeout feature is replaced with the Change Notify feature. This new feature
depends on Linux iNotify, which is not available in HP-UX operating systems.
The Samba Server supports a new feature called Change Notify. Change Notify provides the
ability for a client to request notification from the server when changes occur to files or subdirectories
below a directory on a mapped file share. When a file or directory which is contained within the
specified directory is modified, the server notifies the client. The purpose of this feature is to keep
the client screen display up-to-date in Windows Explorer. The result: if a file you are looking at in
Windows Explorer is changed while you are looking at it, you will see the changes on the screen
almost immediately.
The only way to implement this feature in Samba is to periodically scan through every file and
subdirectory below the directory in question and check for changes made since the last scan. This
is a resource intensive operation which has the potential to affect the performance of Samba as
well as other applications running on the system. Two major factors affect how resource intensive
a scan is: the number of directories having a Change Notify request on them, and the size of those
directories. If you have many clients running Windows Explorer (or other file browsers) or if you
have directories on shares with a large number of files and/or subdirectories, each scan cycle
might be very CPU intensive.
I’m very concerned about his issue because most of our users start using the client while their data is on CIFS shares.
Is there any tuning that can be done :
- on the client (Other protocol than Inotifiy ?)
- on the server (CIFS / SMB on a DELL R530 + Windows Server 2016)
[update from SYNC]
https://help.resilio.com/hc/en-us/articles/207755736-Sync-and-SMB-file-shares
Notifications
Sync subscribes to OS notifications to get immediate updates about file changes and start delivering changed files. However, if a synced folder is located on SMB share, it may not be possible to subscribe to file update notifications. Only SMB 3.0 and newer supports notifications (which means, that both your client and server should have SMB 3.0 to get working notifications). If Sync is unable to get notifications, it will only detect file changes during full folder rescan.
Microsoft introduced SMB 3.0 in Windows 8, though it may be installed to your OS with Microsoft Updates (or via any other updates if you are using non-MS OS)
Windows 2016 Server uses SMB 3.1.1, is there any workaround ?
Regards,
Gautier
