In Seafile 7 the top UI buttons are drawn badly and flicker when navigating
Every time you enter a library, first the icons are drawn in wrong order making the UI flicker
this was not the case in v6
This is the drawing sequence that the user sees:
then clicking on a library the top buttons are drawn in this order causing a flicker effect that is disturbing
followed by
So every time you navigate in the UI, the top buttons shift around causing a flicker effect
Please correct this and revert to what was perfect in v6
