Hello together,
I upgraded my Seafile server from verison 6.2.5 to 6.3.4 and now seahub is not starting . I’m runnig debian 9 and I had enjoyed it, but now it’s not working. This is error message when i try to start seahub:
● seahub.service - Seafile hub
Loaded: loaded (/etc/systemd/system/seahub.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2019-01-31 15:14:10 EET; 7min ago
Process: 12090 ExecStart=/usr/share/seafile/seafile-server-latest/seahub.sh start-fastcgi (code=exited, status=1/FAILURE)
Main PID: 12090 (code=exited, status=1/FAILURE)Jan 31 15:13:58 server seahub.sh[12090]: Starting seahub (fastcgi) at 127.0.0.1:8000 …
Jan 31 15:14:05 server seahub.sh[12090]: Unknown command: ‘runfcgi’
Jan 31 15:14:05 server seahub.sh[12090]: Type ‘manage.py help’ for usage.
Jan 31 15:14:05 server seahub.sh[12090]: Warning: File comment has changed since version 6.3, while tablebase_filecomment
is not migrated yet, please consid
Jan 31 15:14:10 server seahub.sh[12090]: Error:Seahub failed to start.
Jan 31 15:14:10 server systemd[1]: seahub.service: Main process exited, code=exited, status=1/FAILURE
Jan 31 15:14:10 server systemd[1]: Failed to start Seafile hub.
Jan 31 15:14:10 server systemd[1]: seahub.service: Unit entered failed state.
Jan 31 15:14:10 server systemd[1]: seahub.service: Failed with result ‘exit-code’.
This is message when I type “journalctl -xe”.
– Unit seahub.service has begun starting up.
Jan 31 15:13:58 server seahub.sh[12090]: LC_ALL is not set in ENV, set to en_US.UTF-8
– Subject: Unit seahub.service has failed
– Defined-By: systemd
– Support: *link for debian support*– Unit seahub.service has failed.
– The result is failed.
Jan 31 15:14:20 server sshd[12261]: Did not receive identification string from ::1 port 34054
Any idea what I can do?
Greetings,
Petar
