During initial setup, SeaFile starts fine. Can’t start SeaHub on ANY port. Error:Seahub failed to start.
It asks me to try again but fails every time. No firewall rules either.
codycayote@test-env:~/Backups-Cody/seafile-server-7.1.4$ ./seahub.sh start-fastcgi
File “/home/codycayote/Backups-Cody/seafile-server-7.1.4/seahub/manage.py”, line 10, in
File “/home/codycayote/Backups-Cody/seafile-server-7.1.4/seahub/thirdpart/django/core/management/init.py”, line 364, in execute_from_command_line
utility.execute()
File “/home/codycayote/Backups-Cody/seafile-server-7.1.4/seahub/thirdpart/django/core/management/init.py”, line 338, in execute
django.setup()
File “/home/codycayote/Backups-Cody/seafile-server-7.1.4/seahub/thirdpart/django/init.py”, line 27, in setup
File “/home/codycayote/Backups-Cody/seafile-server-7.1.4/seahub/thirdpart/django/apps/registry.py”, line 85, in populate
app_config = AppConfig.create(entry)
File “/home/codycayote/Backups-Cody/seafile-server-7.1.4/seahub/thirdpart/django/apps/config.py”, line 94, in create
module = import_module(entry)
File “/usr/lib/python3.6/importlib/init.py”, line 126, in import_module
File “”, line 994, in _gcd_import
File “”, line 971, in _find_and_load
File “”, line 953, in _find_and_load_unlocked
ModuleNotFoundError: No module named ‘captcha’
As in previous post you are missing some python 3 staff. Just go to server manual and check the section on upgrading to 7.1.x. There it tells you which python extras you need to install (like “captcha”). As of 7.1. python 2 is not anymore supported.
