I followed this guide and everything went well until the end the guide was from linux dot com (how to install seafile server run private cloud)
This is the error I’m getting when trying to start seahub
root@illaspire:/var/www/sea/seafile-server-6.2.5# /var/www/sea/seafile-server-latest/./seahub.sh start-fastcgi
File “/var/www/sea/seafile-server-6.2.5/seahub/manage.py”, line 10, in
File “/var/www/sea/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/core/management/init.py”, line 354, in execute_from_command_line
utility.execute()
File “/var/www/sea/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/core/management/init.py”, line 303, in execute
settings.INSTALLED_APPS
File “/var/www/sea/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/conf/init.py”, line 48, in getattr
self._setup(name)
File “/var/www/sea/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/conf/init.py”, line 44, in _setup
self._wrapped = Settings(settings_module)
File “/var/www/sea/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/conf/init.py”, line 92, in init
mod = importlib.import_module(self.SETTINGS_MODULE)
File “/var/www/sea/seafile-server-6.2.5/seahub/thirdpart/importlib-1.0.4-py2.6.egg/importlib/init.py”, line 37, in import_module
import(name)
File “/var/www/sea/seafile-server-6.2.5/seahub/seahub/init.py”, line 3, in
from handlers import repo_created_cb, repo_deleted_cb
File “/var/www/sea/seafile-server-6.2.5/seahub/seahub/handlers.py”, line 4, in
import settings
File “/var/www/sea/seafile-server-6.2.5/seahub/seahub/settings.py”, line 695, in
import seahub_settings
File “/var/www/sea/conf/seahub_settings.py”, line 3
FILE_SERVER_ROOT = ‘192.168.0.29/seafhttp’
SyntaxError: invalid syntax
Error:Seahub failed to start.
Any suggestions? Thanks in advance!
