Hi. I have had a Community Edition Seafile (version 6.3.4) running on Ubuntu 18.04 for a couple of months with no issues. Today I wanted to shut the server down but for some reason “Sudo shutdown now” did not work. That has never happened before.
I reset the server, Seafile starts normally but Seahub fails with
Error:Seahub failed to start.
I’ve looked in all the logs and there are no clues as to what is wrong. I’ve searched this forum and found similar sounding issues but no definitive approach to diagnosing the problem. I’ve tried running seahub as root with the same result so probably not a permissions issue. I’ve deleted all the .pyc files and anything seahub related in /tmp. None of this has produced a different result.
Any ideas where I go from here? Thanks in advance
John
