Seahub Frontend Contribution
I would like to contribute to the Seahub (v7) frontend. Some npm dependencies seem to be private. I am then not able to have a proper dev env to do changes/experiments.
Is there a way to get access to these dependencies?
Which npm dependency is private?
I guess that they are private as some of dependencies in the package.json (master) file are not visible in the npm registry.
On npmjs search for @seafile, I get
In package.json (from master) I can read :
"@seafile/dtable": "0.0.54",
"@seafile/resumablejs": "^1.1.9",
"@seafile/seafile-editor": "^0.2.47",
And in the CI conf there is:
before_install:
  # npm token to fetch private repos
  - echo "//registry.npmjs.org/:_authToken=\${NPM_TOKEN}" > ~/.npmrc
I said dependencies but obviously only one is missing : dtable
The three packages you mentioned are actually public:
@seafile/dtable is an experiment project, not public yet. You can use 7.0 branch to developer instead of the master branch.
Thanks for your reply.
I may have the same kind of issue for other packages on 7.0 branch :
"@seafile/react-data-grid": "^6.1.5",
"@seafile/react-data-grid-addons": "^6.1.5",
For the @seafile/react-data-* packages.
