I’ve got a problem with seahub since upgrading from 6.2.5 to 6.3.x, there is no working CSS. I have tried to reinstall seafile from scratch but still same problem. But the weird thing is my browser can fetch all static files just fine:
https://imgur.com/Q8YwctN
events {
worker_connections 12;
http{
upstream hub {
server 127.0.0.1:8000;
keepalive 2;
upstream files {
server 127.0.0.1:8082;
keepalive 4;
upstream webdav {
server 127.0.0.1:8080;
keepalive 2;
disable_symlinks off;
listen 80;
error_log syslog:server=unix:/dev/log;
access_log syslog:server=unix:/dev/log;
proxy_pass http://hub;
proxy_set_header Host $host;
proxy_read_timeout 1200s;
proxy_pass http://files;
proxy_http_version 1.1;
proxy_connect_timeout 3s;
proxy_read_timeout 3600s;
proxy_send_timeout 3600s;
send_timeout 3600s;
location /seafdav {
fastcgi_pass webdav;
fastcgi_keep_conn on;
#proxy_pass //https://seacloud.cc/; #This will fix the css issue but causes crfs errors
Using somebody elses seafile installation to fetch css will work though, which makes me wonder if the latest version of seafile might ship with broken static files?
