Hi. I have a Community Edition of Seafile (version 6.3.4) running on Raspbian Stretch for a couple of months with no issues. A view days ago, while uploading a large file via the browser ui, the seahub service crashed.
Since then, erverytime i try to start seahub, it fails with:
seafile-server-latest/seahub.sh: line 208: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-
No such file or directory
Error:Seahub failed to start.
I’ve looked in all the logs and they are all empty (nginx and seafile). I also set DEBUG=true in seahub_settings.py, with no result. I’ve searched this forum and found similar sounding issues but no definitive approach to diagnosing the problem.
Any ideas where I go from here? Thanks in advance
Hi IgnatzMcJockel,
please try the following trick: try to start seahub with fastcgi.
seahub.sh start-fastcgi
Even if fastcgi is not supported anymore there are more error messages visible than without it. If you know what the problem is, solve it and then start seahub again without fastcgi.
Best regards
Christoph
Thank you for the fast advice
i tried and got:
./seahub.sh: line 208: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8): No such file or
directory
Starting seahub (fastcgi) at 127.0.0.1:8000 ...
File "/home/pi/seafile/seafile-server-latest/seahub/manage.py", line 10, in <module>
File "/home/pi/seafile/seafile-server-latest/seahub/thirdpart/Django-1.11.15-
py2.7.egg/django/core/management/__init__.py", line 364, in execute_from_command_line
utility.execute()
py2.7.egg/django/core/management/__init__.py", line 308, in execute
settings.INSTALLED_APPS
py2.7.egg/django/conf/__init__.py", line 56, in __getattr__
self._setup(name)
py2.7.egg/django/conf/__init__.py", line 41, in _setup
self._wrapped = Settings(settings_module)
py2.7.egg/django/conf/__init__.py", line 110, in __init__ mod =
importlib.import_module(self.SETTINGS_MODULE)
File "/usr/lib/python2.7/importlib/__init__.py", line 37, in import_module
__import__(name)
File "/home/pi/seafile/seafile-server-latest/seahub/seahub/__init__.py", line 3, in <module>
from handlers import repo_created_cb, repo_deleted_cb, clean_up_repo_trash_cb
File "/home/pi/seafile/seafile-server-latest/seahub/seahub/handlers.py", line 4, in <module>
import settings
File "/home/pi/seafile/seafile-server-latest/seahub/seahub/settings.py", line 763, in <module>
import seahub_settings
File "/home/pi/seafile/conf/seahub_settings.py", line 10, in <module>
DEBUG=true
NameError: name 'true' is not defined
after removing the DEBUG=true from seahub_settings.py and running with fastcgi again i got:
directory
Unknown command: 'runfcgi'
Type 'manage.py help' for usage.
do i have to setup something to use fastcgi ?
Hi Ignatz,
please try again to start without fastcgi:
seahub.sh start
Now it should work because you solved the problem with the wrong debug parameter.
Best regards
Christoph
Hi Christoph,
unfortunately not…
seahub.sh start
still results in:
directory
Did you end up solving this? I’m seeing exactly the same issue.
seafile@vps03:~/seafile-server-7.0.5$ ./seahub.sh start-fastcgi
