Just updated Seafile to 7 and I can’t get the WebUI to get past the message “Sorry, but the requested page could not be found”. The seafile client generates the same error and will not sync properly. Previously I was using version 6.1, apache and fastcgi. Fastcgi is not used any more so i’m trying to use wsgi (i think that’s what its called). I’ve scoured the forums and google. I can’t seem to nail down this problem. Apache works fine by itself. Its everything under the /seafile subdirectory that is giving me issues.
I believe this is directly related to the errors i’m seeing in seahub.log, the double // look fishy. I just don’t know where I can adjust this.
Seahub.log
2019-11-19 21:42:03,067 [WARNING] django.request:152 get_response Not Found: //
2019-11-19 21:42:04,453 [WARNING] django.request:152 get_response Not Found: //
2019-11-19 21:42:05,404 [WARNING] django.request:152 get_response Not Found: //
2019-11-19 21:43:34,499 [WARNING] django.request:152 get_response Not Found: //api2/repos/
2019-11-19 21:46:13,150 [WARNING] django.request:152 get_response Not Found: //api2/repos/
2019-11-19 21:48:34,430 [WARNING] django.request:152 get_response Not Found: //api2/repos/
2019-11-19 21:51:12,602 [WARNING] django.request:152 get_response Not Found: //api2/repos/
2019-11-19 21:53:34,430 [WARNING] django.request:152 get_response Not Found: //api2/repos/
2019-11-19 21:56:12,654 [WARNING] django.request:152 get_response Not Found: //api2/repos/
2019-11-19 21:58:34,434 [WARNING] django.request:152 get_response Not Found: //api2/repos/
2019-11-19 22:01:13,142 [WARNING] django.request:152 get_response Not Found: //api2/repos/
2019-11-19 22:03:34,434 [WARNING] django.request:152 get_response Not Found: //api2/repos/
2019-11-19 22:06:12,530 [WARNING] django.request:152 get_response Not Found: //api2/repos/
2019-11-19 22:08:34,431 [WARNING] django.request:152 get_response Not Found: //api2/repos/
Ubuntu 18, Apache 2.4.29, and Seafile 7.0.5
Seafile runs in a subdirectory behind apache. Until this update it was working great.
http traffic is redirected to https
Here are my config files.
Apache default-ssl.conf
<IfModule mod_ssl.c>
<VirtualHost *:443>
ServerName my.server.com
ServerAdmin webmaster@localhost
DocumentRoot /var/www/html
<Directory /var/www/html>
Options -Indexes
AllowOverride all
</Directory>
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
SSLCertificateFile /etc/letsencrypt/live/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/key.pem
Include /etc/letsencrypt/options-ssl-apache.conf
SSLCertificateChainFile /etc/letsencrypt/live/chain.pem
Alias /seafmedia /opt/seafile/seafile-server-latest/seahub/media
Alias /media /opt/seafile/seafile-server-latest/seahub/media
<Location /media>
Require all granted
</Location>
SSLEngine On
RewriteEngine On
# seafile fileserver
# seahub
ProxyPreserveHost On
ProxyPass /seafile http://127.0.0.1:8000/
ProxyPassReverse /seafile http://127.0.0.1:8000/
</VirtualHost>
</IfModule>
Apache default.conf
<VirtualHost *:80>
ErrorDocument 404 /index.html
<Directory "/var/www/html">
Options -Indexes
</Directory>
RewriteEngine on
RewriteCond %{SERVER_NAME} =my.server.com
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
ccnet.conf
[General]
USER_NAME = server
ID = [edit]
NAME = server
SERVICE_URL = https://my.server.com/seafile
[Client]
PORT = 13419
[Database]
ENGINE = mysql
HOST = 127.0.0.1
PORT = 3306
USER = seafile
PASSWD = pw
DB = ccnet-db
CONNECTION_CHARSET = utf8
seafile.conf
[fileserver]
port = 8082
[database]
type = mysql
host = 127.0.0.1
port = 3306
user = seafile
password = pw
db_name = seafile-db
connection_charset = utf8
[seahub]
port = 8000
fastcgi = false
seahub_settings.py
# -*- coding: utf-8 -*-
SECRET_KEY = "[edit]"
DATABASES = {
'default': {
'NAME': 'seahub-db',
'USER': 'seafile',
'PASSWORD': 'pw',
'HOST': '127.0.0.1',
'PORT': '3306'
EMAIL_USE_TLS = True
EMAIL_HOST = 'my.server.com' # smtp server
EMAIL_HOST_USER = '' # username and domain
EMAIL_HOST_PASSWORD = '' # password
EMAIL_PORT = 25
FILE_SERVER_ROOT = 'https://my.server.com/seafhttp'
SERVE_STATIC = False
MEDIA_URL = '/media/'
COMPRESS_URL = MEDIA_URL
STATIC_URL = MEDIA_URL + 'assets/'
SITE_ROOT = '/seafile/'
LOGIN_URL = '/seafile/accounts/login/' # NOTE: since version 5.0.4
gunicorn.conf
import os
daemon = True
workers = 5
# default localhost:8000
bind = "127.0.0.1:8000"
# Pid
pids_dir = '/opt/seafile/pids'
timeout = 1200
limit_request_line = 8190
More logs
ccnet.log
[11/19/19 15:34:35] ../common/session.c(398): Accepted a local client
[11/19/19 15:34:48] ../common/session.c(398): Accepted a local client
[11/19/19 15:34:48] ../common/peer.c(943): Local peer down
[11/19/19 15:35:05] ../common/session.c(398): Accepted a local client
[11/19/19 15:42:03] ../common/session.c(398): Accepted a local client
[11/19/19 15:42:05] ../common/session.c(398): Accepted a local client
seafile.log
[11/19/19 15:34:35] http-server.c(175): fileserver: worker_threads = 10
[11/19/19 15:34:35] http-server.c(190): fileserver: fixed_block_size = 8388608
[11/19/19 15:34:35] http-server.c(205): fileserver: web_token_expire_time = 3600
[11/19/19 15:34:35] http-server.c(220): fileserver: max_indexing_threads = 1
[11/19/19 15:34:35] http-server.c(235): fileserver: max_index_processing_threads= 3
[11/19/19 15:34:35] http-server.c(257): fileserver: cluster_shared_temp_file_mode = 600
[11/19/2019 03:34:35 PM] ../common/mq-mgr.c(54): [mq client] mq cilent is started
controller.log
[11/19/19 15:23:08] seafile-controller.c(596): seafdav not enabled.
[11/19/19 15:34:10] seafile-controller.c(634): shutting down ccnet-server ...
[11/19/19 15:34:34] seafile-controller.c(175): starting ccnet-server ...
[11/19/19 15:34:34] seafile-controller.c(79): spawn_process: ccnet-server -F /opt/seafile/conf -c /opt/seafile/ccnet -f /opt/seafile/logs/ccnet.log -d -P /opt/seafile/pids/ccnet.pid
[11/19/19 15:34:34] seafile-controller.c(94): spawned ccnet-server, pid 10471
[11/19/19 15:34:35] seafile-controller.c(623): ccnet daemon connected.
[11/19/19 15:34:35] seafile-controller.c(207): starting seaf-server ...
[11/19/19 15:34:35] seafile-controller.c(79): spawn_process: seaf-server -F /opt/seafile/conf -c /opt/seafile/ccnet -d /opt/seafile/seafile-data -l /opt/seafile/logs/seafile.log -P /opt/seafile/pids/seaf-server.pid
[11/19/19 15:34:35] seafile-controller.c(94): spawned seaf-server, pid 10475
[11/19/19 15:34:35] seafile-controller.c(596): seafdav not enabled.
Any guidance would be appreciated. I’m not sure where else to look for a problem.
