When I try to see a file “in the cloud” from the client app, I get an error “Sorry but the asked page can’t be find”.
I must go on logo (left up corner) to go to the racine and find the good way to my file / folder.
Do you know where does this come from?
Thanks for your help.
Best regards.
NC
NB:
Client and server are up to date.
Problem is on all client computers (mac or pc).
Here is the link detail (which indicate error):
http://nuage.adrdop.com:8000/client-login/:8000/library/f7656fa5-d013-4e06-802e-5e48f969dcb3/Datas_s+n/
IS it normal there is 2 times “:8000”?
If not, where can I fix it?
Thanks.
NC
I think it is a bug in the client.
And there also has been another bug report which I currently can’t find.
