Send files with Android device
I have a problem that not see if my config f server or other ? I can’t upload files with Android application : it failed …
I use seafile 6.2.5. and last Android client version.
I not see errors. Only Failed …
Any help ?
What about downloads? Can you download something from the Seafile app? Also, what version of OS are you using and on what OS? Are you behind NGinx/Apache? Also, what version is what you are calling the “last Android client version”. There are different latest versions depending upon where you grabbed it from.
Hello
==> Yes in web version I can download but not in Android app
==> I using Ubuntu 16.04
==> I am behind Apache
==> I have the version : 2.2.1
Thanks
the latest version of the client is 2.2.3 and fixes the failed download
But in App store only have 2.2.1…
I download the verison 2.2.3 but now it say that I transfered but nothing in the server …
Also when I want to see a image existing nothing appear …
Last I checked, 2.2.3 had some bugs. 2.2.1 is the latest stable version.
So, you can’t upload or download with the Seafile app, correct? Can you try to do a download and upload, then post the server log files here.
Exact.
I upload file to server with Android and got in seafile.log :
[04/28/2018 09:49:04 PM] size-sched.c(96): Repo size compute queue size is 0
And in seahub_django_request.log :
2018-04-28 16:52:27,646 [ERROR] django.request:256 handle_uncaught_exception Internal Server Error: /cloud/shib-login/
File “/media/sata/cloud-server/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/core/handlers/base.py”, line$
% (callback.module, view_name))
ValueError: The view seahub.views.sso.shib_login didn’t return an HttpResponse object. It returned None instead.
2018-04-28 16:54:35,004 [WARNING] django.request:170 get_response Not Found: /cloud/seafhttp/upload-api/20b89364-623c-446a-ae7a-c1$
2018-04-28 16:56:01,904 [WARNING] django.request:170 get_response Not Found: /cloud/seafhttp/update-api/7d3d4121-b965-4809-b824-ec$
2018-04-28 18:48:35,773 [WARNING] django.request:170 get_response Not Found: /cloud/seafhttp/files/4e84f59f-35a3-4dc1-b4a4-3eae716$
2018-04-28 19:53:07,726 [WARNING] django.request:170 get_response Not Found: /cloud/seafhttp/upload-api/ff09f4b6-1123-4231-82e6-e6$
2018-04-28 19:53:20,874 [WARNING] django.request:170 get_response Not Found: /cloud/seafhttp/upload-api/bbc11896-d322-44ae-831d-32$
2018-04-28 19:53:26,400 [WARNING] django.request:170 get_response Not Found: /cloud/seafhttp/update-api/9aae3cfc-3fee-4211-a613-80$
I remark that it not works in the web version…
Thanks
Your webserver configuration is wrong. Instead of sending requests to seafile-server you acutally send them to seahub.
and in where file is wrong ?
I use this : https://manual.seafile.com/deploy/https_with_apache.html
to configure the vhost
you are right ! I wrong config. I found the bug and now works.
But now I must use the 2.2.1 (in Google play) or the 2.2.3 ?
2.2.1 works fine with 6.2.5. Last I checked, 2.2.3 still had some bugs.
Okay that I must go back to version 2.2.1 ?
If buggy why the 2.2.3 is on GitHub to last release tag and not another ?
It could be helpful if you give a short description where there error actually was in case someone else runs into something similar.
