So fast-cgi has been dropped, is there a chapter in the manual how to migrate?
just wondered why i cant switch from community server 6.2.5. to 6.3.4 ("Unknown command: ‘runfcgi’
") and found out, that fast-cgi support had been dropped:
Is there a doc about migration?
Thanks
https://manual.seafile.com/deploy/upgrade.html
https://manual.seafile.com/changelog/server-changelog.html
6.2
From 6.2, It is recommended to use WSGI mode for communication between Seahub and Nginx/Apache. Two steps are needed if you’d like to switch to WSGI mode:
Change the config file of Nginx/Apache.
Restart Seahub with ./seahub.sh start instead of ./seahub.sh start-fastcgi
The configuration of Nginx is as following:
         proxy_read_timeout  1200s;
The configuration of Apache is as following:
# seahub
Would you mind committing this to the community manual in the upgrade section?
Just push the code, I’ll clean it up structurewise afterwards.
Thanks!
yes, it could help seafile users
I would like try this procedure to solve my seafile server problem (not working after upgrade) but i don’t know where to find:
Where do i find this config file and what is usualy the name of this file
I allso vaguely remember i automated the startup op the seahub.sh but i can not find where i did that 2 years ago, anybody an idea what a common way is to automate startup processes in a debian server.
If i get it together i would like to try to make a step by step manual for other users like me who don’t work with linux debian on an daily basis.
What would be good place to post a manual like that?
Kind Regards
Gerard
i found a file called 000-default.conf and it seems to me this what i need to edit so this so i put in the lines on the seahub section:
But i think suhub still starts as fast cgi
—cut—
Warning: File comment has changed since version 6.3, while table `base_filecomm$
^[[33mError:Seahub failed to start.^[[m
—end cut—
How/where do i change that??
Kind Regards
Gerard
