[SOLVED] Fail2Ban not working
Hi
I’m trying to get F2B working on Pro v6.2.10.
fail2ban-regex shows several hundred hits and fail2ban-client shows the jail so I’m confident that I’ve got the F2B files correct - just cut and paste from the manual. I’ve also added a TIME_ZONE line. But despite everything, I have nothing in the jail. I’ve checked all the ownerships and permissions and they seem fine too.
My seahub_settings.py file is
# -*- coding: utf-8 -*-
SECRET_KEY = "<it's a secret>"
DATABASES = {
    'default': {
        'NAME': 'seahub-db',
        'USER': 'seafile',
        'PASSWORD': '<secret>',
        'HOST': '127.0.0.1',
        'PORT': '3306'
TIME_ZONE = 'Europe/London'
Any idea what I’ve missed?
Can you post your fail2ban config?
I had the same problem before, failban does not block IP of incorrect logins but I narrowed it down because the LOGIN_ATTEMPT_LIMIT is not set.
LOGIN_ATTEMPT_LIMIT = 3
This wasn’t my issue.
I was being stupid - I was testing from my workhorse laptop and I had added that IP address to the ignoreip setting in jail.conf so I could never lock myself out!!
But it was your prompting to look for the LOGIN_ATTEMPT_LIMIT setting which caused me to spot my mistake, so I am very grateful. Thank you.
Marked solved
