[SOLVED] Fsck is looking for 'seafile-db.Repo'?
Hi!
Unfortunately my debian server was broken. So I got a new hdd and installed a blank debian. I copied my seafile foder and my mysql databases on the new server and trying to run seaf-fsck. I always get the following result:
Starting seaf-fsck, please wait ...
[04/21/18 16:57:29] ../../common/seaf-db.c(206): Error exec query SELECT repo_id FROM Repo: mysql_stmt_prepare failed: Table 'seafile-db.Repo' doesn't exist in engine.
seaf-fsck run done
Done.
My databases all have the default names. I don’t know why it is looking for ‘seafile-db.Repo’?
I’m using seafile-server_6.2.5_i386.
Best Regards
Dennis
Seaf-fsck compares the tables with the folders. Did you make logical backups or physical backups of your databases?
I copied the seafile-folder by using ‘cp’, however the location changed on the new system. So I adjusted ccnet/seafile.ini
I copied the databases in /var/lib/mysql into the new system, since I unfortunately don’t have sql dumps. The databases are accessible by ‘mysql’ command.
I still have the original hard drive and files are accessible. However I am not able to boot from that disk due to broken sectors.
If you are using the old MySQL database in a different folder on the new machine, you’ll also have to let MySQL know where you moved it. You can find instructions on how to do this in Step 2 of this instruction set:
Thanks a lot!
The problem was actually, that I have only restored the three mysql databases before. Restoring the whole mysql folder according to your link does the trick :slight_smile:
Good to hear it is working. Please edit the title of this thread and place [SOLVED] at the beginning of it.
@Shoeper, you can now mark this one as solved.
