Hey there,
after an upgrade from 6.1.1 to 6.2.3 there is just one library which is broken.
If I try to open it, it says in german “Bibliothek ist nicht vorhanden” (in engl. Library is missing or not available). Before I made this upgrade I had no Problems with it.
Every other Library just works fine …
Any suggestions how I can restore this library or can fix this issue.
Logs did not give any hint. Just saying, that the Commit cannot find the head (just about) …
Thanks
EDIT
Want to add some more Informations:
The Library which is broken still needs space (about 50 GB), but I can not open, access, edit or sync it in any way …
