[SOLVED]OnlyOffice Integration not working
Hi
I just tried OnlyOffice integration, followed instructions exactly but I can’t get documents to load.
First of all this:
https://mydomain/onlyofficeds/welcome works fine
Second, I tried to load a document (empty or otherwise), no errors on console or logs, it looks as if it should work but it stays like this for a while:
Then it errors out.
Has anyone tried the integrations recently?
NGINX config:
    listen       80;
    server_name  files.redacted.com;
    rewrite ^ https://$http_host$request_uri? permanent;    # force redirect http to https
    server_tokens off;
    location ^~ /.well-known/acme-challenge/ {
       default_type "text/plain";
       root /var/www/letsencrypt;
    "" $scheme;
    "" $host;
    default upgrade;
    "" close;
    listen 443;
    ssl on;
    ssl_certificate /etc/letsencrypt/live/files.redacted.com/fullchain.pem;     # path to your cacert.pem
    ssl_certificate_key /etc/letsencrypt/live/files.redacted.com/privkey.pem;   # path to your privkey.pem
    ssl_session_timeout 5m;
    #ssl_dhparam /etc/nginx/dhparam.pem;
    # secure settings (A+ at SSL Labs ssltest at time of writing)
    # see https://wiki.mozilla.org/Security/Server_Side_TLS#Nginx
    ssl_ciphers 'ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES$
    ssl_prefer_server_ciphers on;
    server_tokens off;
        proxy_read_timeout  1200s;
        proxy_read_timeout  36000s;
        proxy_send_timeout  36000s;
        root /home/redacted/seafile/seafile-server-latest/seahub;
    location /seafdav {
  location /onlyofficeds/ {
        proxy_pass http://192.168.200.71:8090/;
        proxy_http_version 1.1;
        proxy_read_timeout 3600s;
        proxy_connect_timeout 3600s;
NVM, DNS issue :slight_smile:
Please post your solution. -Thanks
