[SOLVED]Seadrive Failed to install Kernel driver on MacOS
Hi guys,
I got a MacOS High Sierra 10.13.6 on latest MacBook Pro 2018.
I tried to launch seadrive with root command in terminal but no luck.
The command i use is:
sudo /Applications/SeaDrive.app/Contents/MacOs/seadrive-gui
All i get is Failed to initialize : failed to install kernel driver.
Any tips are welcome
Ty
I reply to myself we need to authorize installation from anywhere on last version of Sierra
