Hi
I am not getting the Seafile-CLI running on an ARM board.
Basing the installtion on the 6.1.7 client.
After doing the installtion according to the manual, i get the error that ccnet module does not exist (see below).
What could I do to solve this?
This cost all my easter weekend
seafile@helios4:~$ seaf-cli init -d ~/.seafile-client
File “/home/seafile/bin/seaf-cli”, line 95, in
import ccnet
ImportError: No module named ccnet
I used the typical installation in the /usr folder.
That worked.
wthess
April 2, 2018, 8:58am
3
You beat me to it… I noticed that you said you are using ARM. ARM installations use 3 or 4 different folders (/usr, /opt, /var, and a seafile folder) upon install whereas the Linux version of Seafile uses only one.
@shoeper - Another one we can mark as solved.
dnichk
October 19, 2018, 3:07am
4
Sorry for the silly question, but what do you mean by:
I’m following the located at https://help.seafile.com/en/syncing_client/linux-cli.html and would expect that following the official docs would account for the requirements to avoid this error.
In my case I am running on Ubuntu 18.04 and installed via the seafile clients PPA.
Thank you in advance for the clarification.
Hi
I don’t really remember. Are you running the Ubuntu 18 on an ARM board?
