SQLAlchemy error
I migrate from a Seattle Pro 6.2 to a new Seafile Pro 7.0.9 on centos.
Everything works fine but we have some slowness randomly, in the log I got this error every 3-4 hours…
[ERROR] error when handle msg <ccnet.message.Message object at 0x7f346b79d090>
  File "/opt/seafile/seafile-pro-server-7.0.9/pro/python/seafevents/app/mq_listener.py", line 46, in handle_message
    func (session, msg)
  File "/opt/seafile/seafile-pro-server-7.0.9/pro/python/seafevents/events/handlers.py", line 86, in RepoUpdateEventHandler
    save_file_histories(session, records)
  File "/opt/seafile/seafile-pro-server-7.0.9/pro/python/seafevents/events/handlers.py", line 398, in save_file_histories
    save_filehistory(session, record)
  File "/opt/seafile/seafile-pro-server-7.0.9/pro/python/seafevents/events/db.py", line 221, in save_filehistory
    while session.query(exists().where(FileHistory.file_uuid == file_uuid)).scalar():
  File "/opt/seafile/seafile-pro-server-7.0.9/seahub/thirdpart/sqlalchemy/orm/query.py", line 3322, in scalar
    ret = self.one()
  File "/opt/seafile/seafile-pro-server-7.0.9/seahub/thirdpart/sqlalchemy/orm/query.py", line 3292, in one
    ret = self.one_or_none()
  File "/opt/seafile/seafile-pro-server-7.0.9/seahub/thirdpart/sqlalchemy/orm/query.py", line 3261, in one_or_none
    ret = list(self)
  File "/opt/seafile/seafile-pro-server-7.0.9/seahub/thirdpart/sqlalchemy/orm/query.py", line 3334, in __iter__
    return self._execute_and_instances(context)
  File "/opt/seafile/seafile-pro-server-7.0.9/seahub/thirdpart/sqlalchemy/orm/query.py", line 3359, in _execute_and_instances
    result = conn.execute(querycontext.statement, self._params)
  File "/opt/seafile/seafile-pro-server-7.0.9/seahub/thirdpart/sqlalchemy/engine/base.py", line 988, in execute
    return meth(self, multiparams, params)
  File "/opt/seafile/seafile-pro-server-7.0.9/seahub/thirdpart/sqlalchemy/sql/elements.py", line 287, in _execute_on_connection
    return connection._execute_clauseelement(self, multiparams, params)
  File "/opt/seafile/seafile-pro-server-7.0.9/seahub/thirdpart/sqlalchemy/engine/base.py", line 1107, in _execute_clauseelement
    distilled_params,
  File "/opt/seafile/seafile-pro-server-7.0.9/seahub/thirdpart/sqlalchemy/engine/base.py", line 1248, in _execute_context
    e, statement, parameters, cursor, context
  File "/opt/seafile/seafile-pro-server-7.0.9/seahub/thirdpart/sqlalchemy/engine/base.py", line 1466, in _handle_dbapi_exception
    util.raise_from_cause(sqlalchemy_exception, exc_info)
  File "/opt/seafile/seafile-pro-server-7.0.9/seahub/thirdpart/sqlalchemy/util/compat.py", line 398, in raise_from_cause
    reraise(type(exception), exception, tb=exc_tb, cause=cause)
  File "/opt/seafile/seafile-pro-server-7.0.9/seahub/thirdpart/sqlalchemy/engine/base.py", line 1244, in _execute_context
    cursor, statement, parameters, context
  File "/opt/seafile/seafile-pro-server-7.0.9/seahub/thirdpart/sqlalchemy/engine/default.py", line 552, in do_execute
    cursor.execute(statement, parameters)
InterfaceError: (sqlite3.InterfaceError) Error binding parameter 0 - probably unsupported type.
[SQL: SELECT EXISTS (SELECT *
FROM "FileHistory"
WHERE "FileHistory".file_uuid = ?) AS anon_1]
[parameters: (UUID('ab8168df-542f-41a8-bdc5-f7b742555682'),)]
(Background on this error at: http://sqlalche.me/e/rvf5)
Can anybody know what’s this mean? Look an error with sqlite but why?
Seafile Pro does not support SQLite.
Seafile run with MYSQL, its only the seafevents that run on a SQLite (don’t know why its a Seafile Pro Fresh install…)
