Hi!
On Windows, is it possible to run the seaf-daemon without the GUI app(let) ?
So it would sync, but not consume resources for the app, which (I guess) is only a control panel and all the work is done by the daemon?
Regards,
David
Hi!
Regards,
David
As far as I know this will work with the command line client. In the other hand the gui does not really consume much memory.
Does this cause issues for you?
It saves you 12,5 MiB of ram. Not sure if thats worth any time.
It also saves a place in the systray and removes one point of failure.
