Hello
I recently started using the Seafile-fuse extension and it works great. However is it possible to start it at system boot and how can I add it to the auto start together with the Seafile and Seahub?
Thanks
Hello
Thanks
Did you get an answer or work this one out? I have the same problem.
Hello
sorry no solution for it
Hello JonathanB
I found a solution for it
sudo nano /etc/systemd/system/seafuse.service
(copie below code and past in file)
[Unit]
Description=Seafile fuse
After=network.target seafile.service seahub.service
[Service]
Type=forking
ExecStart=/home/seafile/seafile-server-latest/seaf-fuse.sh start -o allow_other>
ExecStop=/home/seafile/seafile-server-latest/seaf-fuse.sh stop
User=seafile
Group=seafile
[Install]
WantedBy=multi-user.target
(save and exit)
sudo systemctl enable seafuse.service
that worked for me
sorry in my reply there is a # missing in front of the line of change start
