Subfolder sync error on 6.2 pro beta
HI,
i’m on 6.2 pro and win client 6.1.3.
When i try to sync a subfolder i receive the error “impossible to create the library”
In the applet.log I have
[11/11/17 12:24:59]Échec de création de la bibliothèque
[11/11/17 12:25:07]QString::arg: Argument missing: &G?n?rer un lien de t?l?chargement, Seafile
[11/11/17 12:25:12]setGeometry: Unable to set geometry 689x313+685+400 on QWidgetWindow/'DownloadRepoDialogWindow'. Resulting geometry:  689x312+685+400 (frame: 9, 38, 9, 9, custom margin: 0, 0, 0, 0, minimum size: 425x250, maximum size: 16777215x250).
[11/11/17 12:25:33]QString::arg: Argument missing: &G?n?rer un lien de t?l?chargement, Seafile
[11/11/17 12:25:36]request failed for https://server.domain.fr/api2/repos/4087dd7a-9921-48fa-bb57-8418eb959b2e/: {"error_msg":"Library not found."}
[11/11/17 12:25:37]Échec de création de la bibliothèque
[11/11/17 12:26:43]setGeometry: Unable to set geometry 689x313+685+400 on QWidgetWindow/'DownloadRepoDialogWindow'. Resulting geometry:  689x312+685+400 (frame: 9, 38, 9, 9, custom margin: 0, 0, 0, 0, minimum size: 425x250, maximum size: 16777215x250).
But syncing the whole library is ok
It may be related to this post
regards,
Gautier
This is a bug of 6.2.0 pro. It will be fixed in the next release.
Thank you, Daniel !
Regards
