Quite sure it’s not the right forum , but just asking if someone stumbled on the same issue. Updated my server from 6.x to 7.1.x , and now I can only sync from Seafile to my android device , not the other way.
Someone else stumbled upon the same issue ?
Not sure but if you have Webdav enabled you could try that way with Synchronize Ultimate or Autosync
Same problem as grax. If i choose Seafile, no file or directory would be copied. If i choose WebDav, it’s all fine.
But i don’t want to enable WebDav in my server…
99% is a Synchronize Ultimate, which doesn’t support latest api.
I also wrote to them, but without luck
