Syncing libraries not possible
I have followed the documentation and installed Seafile Server 6.3.2 for Raspberry Pi on Raspbian 9 with Apache and MariaDB. The software is up-to-date. Everything, including the entire web interface, works properly. Moreover, I have installed the Seafile Client on Debian 9. Logging in and viewing as well as modifying libraries works without problems, however syncing a library does not work since the server denies access for some reason.
Client-logs
seafile.log
[08/04/18 23:47:20] seaf-daemon.c(558): starting seafile client 6.1.8
[08/04/18 23:47:20] ../common/mq-mgr.c(60): [mq client] mq cilent is started
[08/04/18 23:47:20] ../common/mq-mgr.c(106): [mq mgr] publish to heartbeat mq: seafile.heartbeat
[08/04/18 23:47:20] seafile-session.c(422): Moving commits for deleted repo a1f46990-88b6-4e17-8b9c-3e7d733e9e4e.
[08/04/18 23:47:20] seafile-session.c(422): Moving fs for deleted repo a1f46990-88b6-4e17-8b9c-3e7d733e9e4e.
[08/04/18 23:47:20] repo-mgr.c(6609): Removing store /home/user/desktop/SF-Test/Seafile/.seafile-data/deleted_store/commits/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e
[08/04/18 23:47:20] repo-mgr.c(6609): Removing store /home/user/desktop/SF-Test/Seafile/.seafile-data/deleted_store/fs/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e
[08/04/18 23:47:30] clone-mgr.c(847): Transition clone state for a1f46990 from [init] to [check server].
[08/04/18 23:47:30] clone-mgr.c(847): Transition clone state for a1f46990 from [check server] to [fetch].
[08/04/18 23:47:30] http-tx-mgr.c(1153): Transfer repo 'a1f46990': ('normal', 'init') --> ('normal', 'check')
[08/04/18 23:47:30] http-tx-mgr.c(1153): Transfer repo 'a1f46990': ('normal', 'check') --> ('normal', 'commit')
[08/04/18 23:47:30] http-tx-mgr.c(1153): Transfer repo 'a1f46990': ('normal', 'commit') --> ('normal', 'fs')
[08/04/18 23:47:30] http-tx-mgr.c(1153): Transfer repo 'a1f46990': ('normal', 'fs') --> ('normal', 'data')
[08/04/18 23:47:30] http-tx-mgr.c(4261): Bad response code for GET https://cloud.MYDOMAIN.com/seafhttp/repo/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e/block/8663a70ef30a5987b440a621483af2044bae1e0a: 403.
[08/04/18 23:47:30] repo-mgr.c(5209): Transfer failed.
[08/04/18 23:47:30] http-tx-mgr.c(1153): Transfer repo 'a1f46990': ('normal', 'data') --> ('error', 'finished')
[08/04/18 23:47:30] clone-mgr.c(864): Transition clone state for a1f46990 from [fetch] to [error]: fetch.
[08/04/18 23:47:30] clone-mgr.c(847): Transition clone state for a1f46990 from [error] to [check server].
[08/04/18 23:47:31] http-tx-mgr.c(4261): Bad response code for GET https://cloud.MYDOMAIN.com/seafhttp/repo/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e/block/8663a70ef30a5987b440a621483af2044bae1e0a: 403.
[08/04/18 23:47:31] repo-mgr.c(5209): Transfer failed.
[08/04/18 23:47:31] http-tx-mgr.c(1153): Transfer repo 'a1f46990': ('normal', 'data') --> ('error', 'finished')
[08/04/18 23:47:31] clone-mgr.c(864): Transition clone state for a1f46990 from [fetch] to [error]: fetch.
[08/04/18 23:47:35] clone-mgr.c(847): Transition clone state for a1f46990 from [error] to [check server].
[08/04/18 23:47:35] clone-mgr.c(847): Transition clone state for a1f46990 from [check server] to [fetch].
[08/04/18 23:47:35] http-tx-mgr.c(1153): Transfer repo 'a1f46990': ('normal', 'init') --> ('normal', 'check')
[08/04/18 23:47:38] http-tx-mgr.c(1153): Transfer repo 'a1f46990': ('normal', 'check') --> ('normal', 'commit')
[08/04/18 23:47:38] http-tx-mgr.c(1153): Transfer repo 'a1f46990': ('normal', 'commit') --> ('normal', 'fs')
[08/04/18 23:47:38] http-tx-mgr.c(1153): Transfer repo 'a1f46990': ('normal', 'fs') --> ('normal', 'data')
[08/04/18 23:47:38] http-tx-mgr.c(4261): Bad response code for GET https://cloud.MYDOMAIN.com/seafhttp/repo/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e/block/8663a70ef30a5987b440a621483af2044bae1e0a: 403.
[08/04/18 23:47:38] repo-mgr.c(5209): Transfer failed.
[08/04/18 23:47:38] http-tx-mgr.c(1153): Transfer repo 'a1f46990': ('normal', 'data') --> ('error', 'finished')
[08/04/18 23:47:38] clone-mgr.c(864): Transition clone state for a1f46990 from [fetch] to [error]: fetch.
[08/04/18 23:47:40] clone-mgr.c(847): Transition clone state for a1f46990 from [error] to [check server].
[08/04/18 23:47:40] clone-mgr.c(847): Transition clone state for a1f46990 from [check server] to [fetch].
[08/04/18 23:47:40] http-tx-mgr.c(1153): Transfer repo 'a1f46990': ('normal', 'init') --> ('normal', 'check')
[08/04/18 23:47:41] http-tx-mgr.c(1153): Transfer repo 'a1f46990': ('normal', 'check') --> ('normal', 'commit')
[08/04/18 23:47:41] http-tx-mgr.c(1153): Transfer repo 'a1f46990': ('normal', 'commit') --> ('normal', 'fs')
[08/04/18 23:47:41] http-tx-mgr.c(1153): Transfer repo 'a1f46990': ('normal', 'fs') --> ('normal', 'data')
[08/04/18 23:47:41] http-tx-mgr.c(4261): Bad response code for GET https://cloud.MYDOMAIN.com/seafhttp/repo/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e/block/8663a70ef30a5987b440a621483af2044bae1e0a: 403.
[08/04/18 23:47:41] repo-mgr.c(5209): Transfer failed.
[08/04/18 23:47:41] http-tx-mgr.c(1153): Transfer repo 'a1f46990': ('normal', 'data') --> ('error', 'finished')
[08/04/18 23:47:41] clone-mgr.c(864): Transition clone state for a1f46990 from [fetch] to [error]: fetch.
[08/04/18 23:47:41] clone-mgr.c(847): Transition clone state for a1f46990 from [error] to [canceled].
It seems, there is a 403-error for some reason.
Server-logs
gunicorn_access.log
127.0.0.1 - - [04/Aug/2018:21:47:23 +0000] "GET /api2/server-info/ HTTP/1.1" 200 51 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:47:23 +0000] "GET /api2/starredfiles/ HTTP/1.1" 200 2 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:47:23 +0000] "GET /api2/account/info/ HTTP/1.1" 200 136 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:47:23 +0000] "GET /api2/events/ HTTP/1.1" 404 35 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:47:23 +0000] "GET /api2/repos/ HTTP/1.1" 200 558 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:47:23 +0000] "GET /api2/ping/ HTTP/1.1" 200 6 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:47:23 +0000] "GET /api2/avatars/user/test@example.com/resized/80/ HTTP/1.1" 200 85 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:47:29 +0000] "GET /api2/repos/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e/download-info/ HTTP/1.1" 200 659 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:50:24 +0000] "GET /api2/ping/ HTTP/1.1" 200 6 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:50:26 +0000] "GET /api2/account/info/ HTTP/1.1" 200 136 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:52:23 +0000] "GET /api2/repos/ HTTP/1.1" 200 558 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:52:23 +0000] "GET /api2/events/ HTTP/1.1" 404 35 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:53:23 +0000] "GET /api2/ping/ HTTP/1.1" 200 6 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:53:23 +0000] "GET /api2/account/info/ HTTP/1.1" 200 136 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:53:24 +0000] "GET /api2/avatars/user/test@example.com/resized/80/ HTTP/1.1" 200 85 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:56:24 +0000] "GET /api2/ping/ HTTP/1.1" 200 6 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:56:24 +0000] "GET /api2/account/info/ HTTP/1.1" 200 136 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:57:23 +0000] "GET /api2/events/ HTTP/1.1" 404 35 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:59:24 +0000] "GET /api2/ping/ HTTP/1.1" 200 6 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:59:24 +0000] "GET /api2/account/info/ HTTP/1.1" 200 136 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:21:59:25 +0000] "GET /api2/avatars/user/test@example.com/resized/80/ HTTP/1.1" 200 85 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:22:00:22 +0000] "GET /api2/repos/ HTTP/1.1" 200 558 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:22:02:23 +0000] "GET /api2/ping/ HTTP/1.1" 200 6 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:22:02:23 +0000] "GET /api2/events/ HTTP/1.1" 404 35 "-" "Mozilla/5.0"
127.0.0.1 - - [04/Aug/2018:22:02:23 +0000] "GET /api2/account/info/ HTTP/1.1" 200 136 "-" "Mozilla/5.0"
seafile.log
[08/04/18 23:46:48] size-sched.c(96): Repo size compute queue size is 0
[08/04/18 23:51:48] size-sched.c(96): Repo size compute queue size is 0
[08/04/18 23:56:48] size-sched.c(96): Repo size compute queue size is 0
[08/05/18 00:01:48] size-sched.c(96): Repo size compute queue size is 0
seahub.log
2018-08-04 21:47:23,801 [WARNING] django.request:152 get_response Not Found: /api2/events/
2018-08-04 21:47:23,813 [WARNING] django.request:152 get_response Not Found: /api2/events/
2018-08-04 21:52:23,634 [WARNING] django.request:152 get_response Not Found: /api2/events/
2018-08-04 21:57:23,262 [WARNING] django.request:152 get_response Not Found: /api2/events/
2018-08-04 22:02:23,709 [WARNING] django.request:152 get_response Not Found: /api2/events/
error.log (Apache)
[Sat Aug 04 23:47:30.545592 2018] [proxy:warn] [pid 9691] AH03408: HTTP: reusable backend connection is not empty: forcibly closed
[Sat Aug 04 23:47:30.748699 2018] [:error] [pid 9691] [client 178.3.82.83:1033] [client 178.3.82.83] ModSecurity: Warning. Match of "rx (?:\\\\x1f\\\\x8b\\\\x08|\\\\b(?:(?:i(?:nterplay|hdr|d3)|m(?:ovi|thd)|r(?:ar!|iff)|(?:ex|jf)if|f(?:lv|ws)|varg|cws)\\\\b|gif)|B(?:%pdf|\\\\.ra)\\\\b)" against "RESPONSE_BODY" required. [file "/usr/share/modsecurity-crs/rules/RESPONSE-953-DATA-LEAKAGES-PHP.conf"] [line "111"] [id "953120"] [rev "2"] [msg "PHP source code leakage"] [data "Matched Data: <? found within RESPONSE_BODY: \\xd0\\xcf\\x11\\xe0\\xa1\\xb1\\x1a\\xe1\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00>\\x00\\x03\\x00\\xfe\\xff\\x09\\x00\\x06\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x05\\x00\\x00\\x00F\\x02\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x10\\x00\\x00H\\x02\\x00\\x00\\x01\\x00\\x00\\x00\\xfe\\xff\\xff\\xff\\x00\\x00\\x00\\x00A\\x02\\x00\\x00B\\x02\\x00\\x00C\\x02\\x00\\x00D\\x02\\x00\\x00E\\x02\\x00\\x00\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff..."] [severity "ERROR"] [ver "OWASP_CRS/3.0.0"] [maturity "9"] [accuracy "9"] [tag "application-multi"] [tag "language-php"] [tag "platform-multi"] [tag "attack-discl [hostname "cloud.MYDOMAIN.com"] [uri "/seafhttp/repo/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e/block/8663a70ef30a5987b440a621483af2044bae1e0a"] [unique_id "W2Ye8n8AAQEAACXb1mMAAAAJ"]
[Sat Aug 04 23:47:30.788854 2018] [:error] [pid 9691] [client 178.3.82.83:1033] [client 178.3.82.83] ModSecurity: Access denied with code 403 (phase 4). Operator GE matched 4 at TX:outbound_anomaly_score. [file "/usr/share/modsecurity-crs/rules/RESPONSE-959-BLOCKING-EVALUATION.conf"] [line "32"] [id "959100"] [msg "Outbound Anomaly Score Exceeded (Total Score: 4)"] [tag "anomaly-evaluation"] [hostname "cloud.MYDOMAIN.com"] [uri "/seafhttp/repo/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e/block/8663a70ef30a5987b440a621483af2044bae1e0a"] [unique_id "W2Ye8n8AAQEAACXb1mMAAAAJ"]
[Sat Aug 04 23:47:30.789808 2018] [:error] [pid 9691] [client 178.3.82.83:1033] [client 178.3.82.83] ModSecurity: Warning. Operator GE matched 4 at TX:outbound_anomaly_score. [file "/usr/share/modsecurity-crs/rules/RESPONSE-980-CORRELATION.conf"] [line "82"] [id "980140"] [msg "Outbound Anomaly Score Exceeded (score 4): PHP source code leakage"] [tag "event-correlation"] [hostname "cloud.MYDOMAIN.com"] [uri "/seafhttp/repo/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e/block/8663a70ef30a5987b440a621483af2044bae1e0a"] [unique_id "W2Ye8n8AAQEAACXb1mMAAAAJ"]
[Sat Aug 04 23:47:31.153528 2018] [:error] [pid 9108] [client 178.3.82.83:1032] [client 178.3.82.83] ModSecurity: Warning. Match of "rx (?:\\\\x1f\\\\x8b\\\\x08|\\\\b(?:(?:i(?:nterplay|hdr|d3)|m(?:ovi|thd)|r(?:ar!|iff)|(?:ex|jf)if|f(?:lv|ws)|varg|cws)\\\\b|gif)|B(?:%pdf|\\\\.ra)\\\\b)" against "RESPONSE_BODY" required. [file "/usr/share/modsecurity-crs/rules/RESPONSE-953-DATA-LEAKAGES-PHP.conf"] [line "111"] [id "953120"] [rev "2"] [msg "PHP source code leakage"] [data "Matched Data: <? found within RESPONSE_BODY: \\xd0\\xcf\\x11\\xe0\\xa1\\xb1\\x1a\\xe1\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00>\\x00\\x03\\x00\\xfe\\xff\\x09\\x00\\x06\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x05\\x00\\x00\\x00F\\x02\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x10\\x00\\x00H\\x02\\x00\\x00\\x01\\x00\\x00\\x00\\xfe\\xff\\xff\\xff\\x00\\x00\\x00\\x00A\\x02\\x00\\x00B\\x02\\x00\\x00C\\x02\\x00\\x00D\\x02\\x00\\x00E\\x02\\x00\\x00\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff..."] [severity "ERROR"] [ver "OWASP_CRS/3.0.0"] [maturity "9"] [accuracy "9"] [tag "application-multi"] [tag "language-php"] [tag "platform-multi"] [tag "attack-discl [hostname "cloud.MYDOMAIN.com"] [uri "/seafhttp/repo/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e/block/8663a70ef30a5987b440a621483af2044bae1e0a"] [unique_id "W2Ye8n8AAQEAACOUxtYAAAAB"]
[Sat Aug 04 23:47:31.193955 2018] [:error] [pid 9108] [client 178.3.82.83:1032] [client 178.3.82.83] ModSecurity: Access denied with code 403 (phase 4). Operator GE matched 4 at TX:outbound_anomaly_score. [file "/usr/share/modsecurity-crs/rules/RESPONSE-959-BLOCKING-EVALUATION.conf"] [line "32"] [id "959100"] [msg "Outbound Anomaly Score Exceeded (Total Score: 4)"] [tag "anomaly-evaluation"] [hostname "cloud.MYDOMAIN.com"] [uri "/seafhttp/repo/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e/block/8663a70ef30a5987b440a621483af2044bae1e0a"] [unique_id "W2Ye8n8AAQEAACOUxtYAAAAB"]
[Sat Aug 04 23:47:31.194884 2018] [:error] [pid 9108] [client 178.3.82.83:1032] [client 178.3.82.83] ModSecurity: Warning. Operator GE matched 4 at TX:outbound_anomaly_score. [file "/usr/share/modsecurity-crs/rules/RESPONSE-980-CORRELATION.conf"] [line "82"] [id "980140"] [msg "Outbound Anomaly Score Exceeded (score 4): PHP source code leakage"] [tag "event-correlation"] [hostname "cloud.MYDOMAIN.com"] [uri "/seafhttp/repo/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e/block/8663a70ef30a5987b440a621483af2044bae1e0a"] [unique_id "W2Ye8n8AAQEAACOUxtYAAAAB"]
[Sat Aug 04 23:47:38.319450 2018] [:error] [pid 9691] [client 178.3.82.83:1033] [client 178.3.82.83] ModSecurity: Warning. Match of "rx (?:\\\\x1f\\\\x8b\\\\x08|\\\\b(?:(?:i(?:nterplay|hdr|d3)|m(?:ovi|thd)|r(?:ar!|iff)|(?:ex|jf)if|f(?:lv|ws)|varg|cws)\\\\b|gif)|B(?:%pdf|\\\\.ra)\\\\b)" against "RESPONSE_BODY" required. [file "/usr/share/modsecurity-crs/rules/RESPONSE-953-DATA-LEAKAGES-PHP.conf"] [line "111"] [id "953120"] [rev "2"] [msg "PHP source code leakage"] [data "Matched Data: <? found within RESPONSE_BODY: \\xd0\\xcf\\x11\\xe0\\xa1\\xb1\\x1a\\xe1\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00>\\x00\\x03\\x00\\xfe\\xff\\x09\\x00\\x06\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x05\\x00\\x00\\x00F\\x02\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x10\\x00\\x00H\\x02\\x00\\x00\\x01\\x00\\x00\\x00\\xfe\\xff\\xff\\xff\\x00\\x00\\x00\\x00A\\x02\\x00\\x00B\\x02\\x00\\x00C\\x02\\x00\\x00D\\x02\\x00\\x00E\\x02\\x00\\x00\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff..."] [severity "ERROR"] [ver "OWASP_CRS/3.0.0"] [maturity "9"] [accuracy "9"] [tag "application-multi"] [tag "language-php"] [tag "platform-multi"] [tag "attack-discl [hostname "cloud.MYDOMAIN.com"] [uri "/seafhttp/repo/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e/block/8663a70ef30a5987b440a621483af2044bae1e0a"] [unique_id "W2Ye@n8AAQEAACXb1mkAAAAJ"]
[Sat Aug 04 23:47:38.359606 2018] [:error] [pid 9691] [client 178.3.82.83:1033] [client 178.3.82.83] ModSecurity: Access denied with code 403 (phase 4). Operator GE matched 4 at TX:outbound_anomaly_score. [file "/usr/share/modsecurity-crs/rules/RESPONSE-959-BLOCKING-EVALUATION.conf"] [line "32"] [id "959100"] [msg "Outbound Anomaly Score Exceeded (Total Score: 4)"] [tag "anomaly-evaluation"] [hostname "cloud.MYDOMAIN.com"] [uri "/seafhttp/repo/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e/block/8663a70ef30a5987b440a621483af2044bae1e0a"] [unique_id "W2Ye@n8AAQEAACXb1mkAAAAJ"]
[Sat Aug 04 23:47:38.360516 2018] [:error] [pid 9691] [client 178.3.82.83:1033] [client 178.3.82.83] ModSecurity: Warning. Operator GE matched 4 at TX:outbound_anomaly_score. [file "/usr/share/modsecurity-crs/rules/RESPONSE-980-CORRELATION.conf"] [line "82"] [id "980140"] [msg "Outbound Anomaly Score Exceeded (score 4): PHP source code leakage"] [tag "event-correlation"] [hostname "cloud.MYDOMAIN.com"] [uri "/seafhttp/repo/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e/block/8663a70ef30a5987b440a621483af2044bae1e0a"] [unique_id "W2Ye@n8AAQEAACXb1mkAAAAJ"]
[Sat Aug 04 23:47:41.390956 2018] [:error] [pid 9108] [client 178.3.82.83:1032] [client 178.3.82.83] ModSecurity: Warning. Match of "rx (?:\\\\x1f\\\\x8b\\\\x08|\\\\b(?:(?:i(?:nterplay|hdr|d3)|m(?:ovi|thd)|r(?:ar!|iff)|(?:ex|jf)if|f(?:lv|ws)|varg|cws)\\\\b|gif)|B(?:%pdf|\\\\.ra)\\\\b)" against "RESPONSE_BODY" required. [file "/usr/share/modsecurity-crs/rules/RESPONSE-953-DATA-LEAKAGES-PHP.conf"] [line "111"] [id "953120"] [rev "2"] [msg "PHP source code leakage"] [data "Matched Data: <? found within RESPONSE_BODY: \\xd0\\xcf\\x11\\xe0\\xa1\\xb1\\x1a\\xe1\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00>\\x00\\x03\\x00\\xfe\\xff\\x09\\x00\\x06\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x05\\x00\\x00\\x00F\\x02\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x10\\x00\\x00H\\x02\\x00\\x00\\x01\\x00\\x00\\x00\\xfe\\xff\\xff\\xff\\x00\\x00\\x00\\x00A\\x02\\x00\\x00B\\x02\\x00\\x00C\\x02\\x00\\x00D\\x02\\x00\\x00E\\x02\\x00\\x00\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff\\xff..."] [severity "ERROR"] [ver "OWASP_CRS/3.0.0"] [maturity "9"] [accuracy "9"] [tag "application-multi"] [tag "language-php"] [tag "platform-multi"] [tag "attack-discl [hostname "cloud.MYDOMAIN.com"] [uri "/seafhttp/repo/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e/block/8663a70ef30a5987b440a621483af2044bae1e0a"] [unique_id "W2Ye-X8AAQEAACOUxtwAAAAB"]
[Sat Aug 04 23:47:41.434866 2018] [:error] [pid 9108] [client 178.3.82.83:1032] [client 178.3.82.83] ModSecurity: Access denied with code 403 (phase 4). Operator GE matched 4 at TX:outbound_anomaly_score. [file "/usr/share/modsecurity-crs/rules/RESPONSE-959-BLOCKING-EVALUATION.conf"] [line "32"] [id "959100"] [msg "Outbound Anomaly Score Exceeded (Total Score: 4)"] [tag "anomaly-evaluation"] [hostname "cloud.MYDOMAIN.com"] [uri "/seafhttp/repo/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e/block/8663a70ef30a5987b440a621483af2044bae1e0a"] [unique_id "W2Ye-X8AAQEAACOUxtwAAAAB"]
[Sat Aug 04 23:47:41.435723 2018] [:error] [pid 9108] [client 178.3.82.83:1032] [client 178.3.82.83] ModSecurity: Warning. Operator GE matched 4 at TX:outbound_anomaly_score. [file "/usr/share/modsecurity-crs/rules/RESPONSE-980-CORRELATION.conf"] [line "82"] [id "980140"] [msg "Outbound Anomaly Score Exceeded (score 4): PHP source code leakage"] [tag "event-correlation"] [hostname "cloud.MYDOMAIN.com"] [uri "/seafhttp/repo/a1f46990-88b6-4e17-8b9c-3e7d733e9e4e/block/8663a70ef30a5987b440a621483af2044bae1e0a"] [unique_id "W2Ye-X8AAQEAACOUxtwAAAAB"]
Config files
ccnet.conf
[General]
USER_NAME = server
ID = 4f0c7218b322c694d9f2c3759589bebdf18aa3bd
NAME = server
SERVICE_URL = https://cloud.MYDOMAIN.com
[Client]
PORT = 13419
[Database]
ENGINE = mysql
HOST = 127.0.0.1
PORT = 3360
USER = seafile
PASSWD = MYPASSWORD
DB = ccnet-db
CONNECTION_CHARSET = utf8
seahub_settings.py
# -*- coding: utf-8 -*-
SECRET_KEY = "8$dj!v(r2_$c_4#9-p739(ztd0)$!)!31p(u+kzoqn^acae_um"
DATABASES = {
    'default': {
        'NAME': 'seahub-db',
        'USER': 'seafile',
        'PASSWORD': 'MYPASSWORD',
        'HOST': '127.0.0.1',
        'PORT': '3360'
FILE_SERVER_ROOT = 'https://cloud.MYDOMAIN.com/seafhttp'
ALLOWED_HOSTS = ['127.0.0.1', 'localhost']
LOGIN_REMEMBER_DAYS = 30
LOGIN_ATTEMPT_LIMIT = 3
SESSION_EXPIRE_AT_BROWSER_CLOSE = False
TEXT_PREVIEW_EXT = """ac, am, bat, c, cc, cmake, cpp, cs, css, diff, el, h, html,
htm, java, js, json, less, make, org, php, pl, properties, py, rb,
scala, script, sh, sql, txt, text, tex, vi, vim, xhtml, xml, log, csv,
groovy, rst, patch, go"""
ENABLE_THUMBNAIL = True
gunicorn.conf
import os
daemon = True
workers = 5
# default localhost:8000
bind = "0.0.0.0:8000"
# Pid
pids_dir = '/home/user/seafile/pids'
# Logging
logs_dir = '/home/user/seafile/logs'
errorlog = os.path.join(logs_dir, 'gunicorn_error.log')
accesslog = os.path.join(logs_dir, 'gunicorn_access.log')
# for file upload, we need a longer timeout value (default is only 30s, too shor$
timeout = 1200
limit_request_line = 8190
seafile.conf
[fileserver]
port = 8082
[database]
type = mysql
host = 127.0.0.1
port = 3360
user = seafile
password = MYPASSWORD
db_name = seafile-db
connection_charset = utf8
/etc/apache2/sites-available/default-ssl.conf (Apache)
# Certificates etc.....
<VirtualHost *:443>
   ServerName cloud.MYDOMAIN.de
   DocumentRoot /var/www/html
   Alias /media /home/user/seafile/seafile-server-latest/seahub/media
   RewriteEngine On
   <Location /media>
      Require all granted
   </Location>
</VirtualHost>
I am using dynamic DNS. Port forwarding is enabled for port 80 and port 443. The firewall is configured to allow TCP-connections on port 80 and port 443. I hope someone can help me with this issue.
ModSecurity (apache module) fucked everything up. Don’t setup any “security” stuff as long as you don’t understand the implications.
That was it! After disabling mod security, everything works fine. Thank you for your fast help!
