Syncing with External Harddrive
I set up a user so that it sync’s with an external harddrive, because syncing to the computer takes up way too much disk space.
After not using seafile for a while or after rebooting it is unsynced.
How can I prevent this?
That should help:
@Simsala thanks, but how exactly do I get to that menu? We use Windows.
Rightclick on the Seafile Icon in the System Tray and then select Settings
