Systemadmin on mobile devices not working
on me mobile version of seahub, the systemadmin interface is not working. It is impossible to view the user- or librarylist. The “three-line”/menu-Button on the top left is missing
The normal frontend with the libraries is working normally.
Tried several mobile browsers on different devices.
Same issue here. But there is a workaround: Just go to the sysadmin panel, then change to the settings panel and after that go back to the sysadmin panel. Now you can get the overview of the user accounts.
That’s a dirty workaround :wink:
Still not possible to view the other menus
This problem still occurs on server 6.0.8
Would be great if this gets fixed soon :slight_smile:
The fix would be included in version 6.1.
