SystemError: unknown opcode with "language.find" error after accessing to Seafile web interface
After starting Seafile server - I got the error in logs after trying to access web interface:
==> ./seahub_django_request.log <==
2018-01-22 09:07:38,374 [ERROR] django.request:256 handle_uncaught_exception Internal Server Error: /
  File "/opt/seafile-server/seafile-server-6.0.8/seahub/thirdpart/Django-1.8.17-py2.7.egg/django/core/handlers/base.py", line 108, in get_response
  File "/opt/seafile-server/seafile-server-6.0.8/seahub/thirdpart/Django-1.8.17-py2.7.egg/django/middleware/locale.py", line 32, in process_request
    request, check_path=check_path)
  File "/opt/seafile-server/seafile-server-6.0.8/seahub/thirdpart/Django-1.8.17-py2.7.egg/django/utils/translation/__init__.py", line 198, in get_language_from_request
    return _trans.get_language_from_request(request, check_path)
  File "/opt/seafile-server/seafile-server-6.0.8/seahub/thirdpart/Django-1.8.17-py2.7.egg/django/utils/translation/trans_real.py", line 523, in get_language_from_request
    return get_supported_language_variant(accept_lang)
  File "/opt/seafile-server/seafile-server-6.0.8/seahub/thirdpart/Django-1.8.17-py2.7.egg/django/utils/lru_cache.py", line 125, in wrapper
    result = user_function(*args, **kwds)
  File "/opt/seafile-server/seafile-server-6.0.8/seahub/thirdpart/Django-1.8.17-py2.7.egg/django/utils/translation/trans_real.py", line 457, in get_supported_language_variant
    if code in supported_lang_codes and check_for_language(code):
  File "/opt/seafile-server/seafile-server-6.0.8/seahub/thirdpart/Django-1.8.17-py2.7.egg/django/utils/translation/trans_real.py", line 419, in check_for_language
    if gettext_module.find('django', path, [to_locale(lang_code)]) is not None:
  File "/opt/seafile-server/seafile-server-6.0.8/seahub/thirdpart/Django-1.8.17-py2.7.egg/django/utils/translation/trans_real.py", line 75, in to_locale
    p = language.find('-')
In web page I see the text:
Page unavailable
Webdav access to storage works normally.
OS is Ubuntu 16.04 amd64.
Seems this is some problem with the language, but I can’t find any configuration variables about language. How can I fix this problem?
Seems the problem with broken Seafile Web interface is in another place - I have found dead symlink seafile-server/seahub-data/avatars to ../../avatars that not exists. After I remove symlink and create normal folder - all works well.
