Transfering Folders to another Group
I am having troubles transferring folders that in one group to another. When I choose “move” under the folder options, the drop down menus does not show the group, nor the folders that I want to move the info to.
Any suggestions as to what may be wrong here?
Thanks!
There are two tabs: one is “current library” and the other is “other libraries”.
Expanding the “other libraries” tab, you should see the library and folder that you want to transfer to.
