I am trying Seafile again since I need something to sync multiple files across three systems. The problem is I constantly get “Failed to index files” errors and it’s driving me nuts. I was told that this could happen with large datasets or large files in general but my file is 482kb.
Can someone please help me figure this out, I have the Seafile Docker running on my Linux server, 2 Linux machines, and a Windows 10 machine. The windows machine doesn’t give me as much trouble as the Linux boxes but I have tried Fedora, Arch, OpenSUSE, and Mint and all give me the same error.
I would love to post my log files but apparently, you can only post images and the log is way too long.
I think this is the problem portion of the log:
[10/06/18 12:36:32] seaf-daemon.c(491): starting seafile client 6.2.5
[10/06/18 12:36:32] seafile-session.c(382): client id = d1f7daf17378f19fc6edc20b0cc38295b31a324c, client_name = unknown
[10/06/18 12:36:32] seaf-daemon.c(518): rpc server started.
[10/06/18 12:37:53] clone-mgr.c(974): Worktree path conflicts with seafile system path.
[10/06/18 12:38:33] clone-mgr.c(713): Transition clone state for 60327f9c from [init] to [check server].
[10/06/18 12:38:33] http-tx-mgr.c(1281): Bad response code for GET http://192.168.1.229:8000/seafhttp/protocol-version: 404.
[10/06/18 12:38:33] clone-mgr.c(713): Transition clone state for 60327f9c from [check server] to [fetch].
[10/06/18 12:38:33] http-tx-mgr.c(1177): Transfer repo '60327f9c': ('normal', 'init') --> ('normal', 'check')
[10/06/18 12:38:33] http-tx-mgr.c(1177): Transfer repo '60327f9c': ('normal', 'check') --> ('normal', 'commit')
[10/06/18 12:38:33] http-tx-mgr.c(1177): Transfer repo '60327f9c': ('normal', 'commit') --> ('normal', 'fs')
[10/06/18 12:38:33] http-tx-mgr.c(1177): Transfer repo '60327f9c': ('normal', 'fs') --> ('normal', 'data')
[10/06/18 12:40:10] http-tx-mgr.c(1177): Transfer repo '60327f9c': ('normal', 'data') --> ('finished', 'finished')
[10/06/18 12:40:10] clone-mgr.c(713): Transition clone state for 60327f9c from [fetch] to [done].
[10/06/18 12:40:11] http-tx-mgr.c(1281): Bad response code for GET http://192.168.1.229:8000/seafhttp/protocol-version: 404.
[10/06/18 12:40:11] sync-mgr.c(1293): File syncing protocol version on server http://192.168.1.229:8082 is 2. Client file syncing protocol version is 2. Use version 2.
[10/06/18 12:40:12] sync-mgr.c(545): Repo 'School' sync state transition from 'synchronized' to 'committing'.
[10/06/18 12:40:12] repo-mgr.c(3793): All events are processed for repo 60327f9c-7569-4be5-9bb4-46bea6c96392.
[10/06/18 12:40:12] sync-mgr.c(545): Repo 'School' sync state transition from 'committing' to 'initializing'.
[10/06/18 12:40:12] sync-mgr.c(850): Removing blocks for repo School(60327f9c).
[10/06/18 12:41:32] repo-mgr.c(5770): Failed to open store dir /home/eric/Documents/School/Seafile/.seafile-data/deleted_store/commits: Error opening directory “/home/eric/Documents/School/Seafile/.seafile-data/deleted_store/commits”: No such file or directory.
[10/06/18 12:41:32] repo-mgr.c(5770): Failed to open store dir /home/eric/Documents/School/Seafile/.seafile-data/deleted_store/fs: Error opening directory “/home/eric/Documents/School/Seafile/.seafile-data/deleted_store/fs”: No such file or directory.
[10/06/18 12:41:32] repo-mgr.c(5770): Failed to open store dir /home/eric/Documents/School/Seafile/.seafile-data/deleted_store/blocks: Error opening directory “/home/eric/Documents/School/Seafile/.seafile-data/deleted_store/blocks”: No such file or directory.
[10/06/18 12:42:32] repo-mgr.c(5770): Failed to open store dir /home/eric/Documents/School/Seafile/.seafile-data/deleted_store/commits: Error opening directory “/home/eric/Documents/School/Seafile/.seafile-data/deleted_store/commits”: No such file or directory.
[10/06/18 12:42:32] repo-mgr.c(5770): Failed to open store dir /home/eric/Documents/School/Seafile/.seafile-data/deleted_store/fs: Error opening directory “/home/eric/Documents/School/Seafile/.seafile-data/deleted_store/fs”: No such file or directory.
[10/06/18 12:42:32] repo-mgr.c(5770): Failed to open store dir /home/eric/Documents/School/Seafile/.seafile-data/deleted_store/blocks: Error opening directory “/home/eric/Documents/School/Seafile/.seafile-data/deleted_store/blocks”: No such file or directory.
[10/06/18 12:43:32] repo-mgr.c(5770): Failed to open store dir /home/eric/Documents/School/Seafile/.seafile-data/deleted_store/commits: Error opening directory “/home/eric/Documents/School/Seafile/.seafile-data/deleted_store/commits”: No such file or directory.
[10/06/18 12:43:32] repo-mgr.c(5770): Failed to open store dir /home/eric/Documents/School/Seafile/.seafile-data/deleted_store/fs: Error opening directory “/home/eric/Documents/School/Seafile/.seafile-data/deleted_store/fs”: No such file or directory.
[10/06/18 12:43:32] repo-mgr.c(5770): Failed to open store dir /home/eric/Documents/School/Seafile/.seafile-data/deleted_store/blocks: Error opening directory “/home/eric/Documents/School/Seafile/.seafile-data/deleted_store/blocks”: No such file or directory.
[10/06/18 12:44:32] repo-mgr.c(5770): Failed to open store dir /home/eric/Documents/School/Seafile/.seafile-data/deleted_store/commits: Error opening directory “/home/eric/Documents/School/Seafile/.seafile-data/deleted_store/commits”: No such file or directory.
[10/06/18 12:44:32] repo-mgr.c(5770): Failed to open store dir /home/eric/Documents/School/Seafile/.seafile-data/deleted_store/fs: Error opening directory “/home/eric/Documents/School/Seafile/.seafile-data/deleted_store/fs”: No such file or directory.
[10/06/18 12:44:32] repo-mgr.c(5770): Failed to open store dir /home/eric/Documents/School/Seafile/.seafile-data/deleted_store/blocks: Error opening directory “/home/eric/Documents/School/Seafile/.seafile-data/deleted_store/blocks”: No such file or directory.
[10/06/18 12:45:32] repo-mgr.c(5770): Failed to open store dir /home/eric/Documents/School/Seafile/.seafile-data/deleted_store/commits: Error opening directory “/home/eric/Documents/School/Seafile/.seafile-data/deleted_store/commits”: No such file or directory.
[10/06/18 12:45:32] repo-mgr.c(5770): Failed to open store dir /home/eric/Documents/School/Seafile/.seafile-data/deleted_store/fs: Error opening directory “/home/eric/Documents/School/Seafile/.seafile-data/deleted_store/fs”: No such file or directory.
[10/06/18 12:45:32] repo-mgr.c(5770): Failed to open store dir /home/eric/Documents/School/Seafile/.seafile-data/deleted_store/blocks: Error opening directory “/home/eric/Documents/School/Seafile/.seafile-data/deleted_store/blocks”: No such file or directory.
When you installed the client and it asked to where to store it’s working data like database, probably you choose the same path as you choose for the library to sync?
please check for the directory, either files or directory seem to not exist
The path for the database is separate from the library. The school folder I deleted but its not my synced library. When I delete it I get that error, not sure why. Everything seems to be working fine on Linux now but Windows doesn’t seem to sync automatically, shouldn’t it sync if I update or change a file?
I am using the docker image on unRaid. The config and database files are stored on an SSD, appdata/Seafile/. The library is stored on the array Seafile/. Everything seems to be working fine after I fixed one of the folder names.
I will be reconfiguring the server so that MariaDB is where the database is stored but other than that everything seems to be syncing fine across all clients.
Thanks for the help.
