Unable to Authenticate with Seafile Openstack
Hey all, I’m using the seafile pro docker image, and I am attempting to enable swift storage as an archive. Using the credentials that I have, I am able to authenticate via the command line, so I know that the info I have is valid, however regardless of how I configure it in the seafile configuration file, I will get an authentication error.
Curious to know if this is a known issue with the pro container, and is there a way to increase the verbosity of the logging to see if I can determine why the authentication is failing.
Thanks in advance.
