Unable to upload - help please
Hello Everyone,
I just setup a Seafile server on a Raspberry Pi. I cannot uplod anything at all from anywhere else. Could someone please help and give an idea on what is wrong. I found the following in the seafile log:
“…/common/block-backend-fs.c(349): Failed to link /mnt/LSCloud/seafile-data/storage/blocks/1d0cd9eb-294a-4b37-8c0a-e28efc41a971/9c/8a0746de629c49763d2f49ed972a2b6cb89bd3 to /mnt/LSCloud/seafile-data/storage/blocks/600cd67f-b360-40f2-8b7a-e5379f14f900/9c/8a0746de629c49763d2f49ed972a2b6cb89bd3: Function not implemented.
[03/03/18 23:26:30] repo-op.c(1832): Failed to copy block 9c8a0746de629c49763d2f49ed972a2b6cb89bd3 from repo 1d0cd9eb-294a-4b37-8c0a-e28efc41a971 to 600cd67f-b360-40f2-8b7a-e5379f14f900.
[03/03/18 23:26:30] …/common/block-backend-fs.c(349): Failed to link /mnt/LSCloud/seafile-data/storage/blocks/1d0cd9eb-294a-4b37-8c0a-e28efc41a971/86/63a70ef30a5987b440a621483af2044bae1e0a to /mnt/LSCloud/seafile-data/storage/blocks/600cd67f-b360-40f2-8b7a-e5379f14f900/86/63a70ef30a5987b440a621483af2044bae1e0a: Function not implemented.
[03/03/18 23:26:30] repo-op.c(1832): Failed to copy block 8663a70ef30a5987b440a621483af2044bae1e0a from repo 1d0cd9eb-294a-4b37-8c0a-e28efc41a971 to 600cd67f-b360-40f2-8b7a-e5379f14f900.”
Thanks a lot,
ladamus
It appears you are trying to sync to a mounted drive, rather than a physical drive. Is it a network drive? External drive? USB drive? If so, I’ve read there are some specific settings you’ll need in order to pull it off. And, I think if you are using a webserver proxy like Apache, there are some settings there as well.
