No other errors, seems to be working perfectly other than the ‘Users’ and ‘Devices’ page in the admin panel say ‘Error’ in red letters.
Seahub log showed
2022-09-27 11:26:40,925 [ERROR] django.request:224 log_response Internal Server Error: /api/v2.1/admin/devices/ Traceback (most recent call last): File "/media/raid1/seafile-server-9.0.9/seahub/thirdpart/django/core/handlers/exception.py", line 47, in inner response = get_response(request) File "/media/raid1/seafile-server-9.0.9/seahub/thirdpart/django/core/handlers/base.py", line 181, in _get_response response = wrapped_callback(request, *callback_args, **callback_kwargs) File "/media/raid1/seafile-server-9.0.9/seahub/thirdpart/django/views/decorators/csrf.py", line 54, in wrapped_view return view_func(*args, **kwargs) File "/media/raid1/seafile-server-9.0.9/seahub/thirdpart/django/views/generic/base.py", line 70, in view return self.dispatch(request, *args, **kwargs) File "/media/raid1/seafile-server-9.0.9/seahub/thirdpart/rest_framework/views.py", line 505, in dispatch response = self.handle_exception(exc) File "/media/raid1/seafile-server-9.0.9/seahub/thirdpart/rest_framework/views.py", line 465, in handle_exception self.raise_uncaught_exception(exc) File "/media/raid1/seafile-server-9.0.9/seahub/thirdpart/rest_framework/views.py", line 476, in raise_uncaught_exception raise exc File "/media/raid1/seafile-server-9.0.9/seahub/thirdpart/rest_framework/views.py", line 502, in dispatch response = handler(request, *args, **kwargs) File "/media/raid1/seafile-server-9.0.9/seahub/seahub/api2/endpoints/admin/devices.py", line 48, in get if len(devices) == end - start: File "/media/raid1/seafile-server-9.0.9/seahub/thirdpart/django/db/models/query.py", line 262, in len self._fetch_all() File "/media/raid1/seafile-server-9.0.9/seahub/thirdpart/django/db/models/query.py", line 1324, in _fetch_all self._result_cache = list(self._iterable_class(self)) File "/media/raid1/seafile-server-9.0.9/seahub/thirdpart/django/db/models/query.py", line 51, in iter results = compiler.execute_sql(chunked_fetch=self.chunked_fetch, chunk_size=self.chunk_size) File "/media/raid1/seafile-server-9.0.9/seahub/thirdpart/django/db/models/sql/compiler.py", line 1208, in execute_sql return list(result) File "/media/raid1/seafile-server-9.0.9/seahub/thirdpart/django/db/models/sql/compiler.py", line 1646, in cursor_iter for rows in iter((lambda: cursor.fetchmany(itersize)), sentinel): File "/media/raid1/seafile-server-9.0.9/seahub/thirdpart/django/db/models/sql/compiler.py", line 1646, in <lambda> for rows in iter((lambda: cursor.fetchmany(itersize)), sentinel): File "/media/raid1/seafile-server-9.0.9/seahub/thirdpart/django/db/utils.py", line 97, in inner return func(*args, **kwargs) File "/media/raid1/seafile-server-9.0.9/seahub/thirdpart/django/db/backends/sqlite3/base.py", line 42, in <lambda> return lambda s: conv_func(s.decode()) File "/media/raid1/seafile-server-9.0.9/seahub/thirdpart/django/utils/dateparse.py", line 122, in parse_datetime return datetime.datetime(**kw) ValueError: year 0 is out of range
After troubleshooting that everything was setup correctly, the only solution I found was:
sqlite3 /path/to/seahub.db
UPDATE api2_tokenv2 SET created_at=‘0001-01-01 00:00:00’ WHERE created_at=‘0000-00-00 00:00:00’;
.quit
This solved my issue.
Added this for visibility/documentation in case anyone else has this same problem.
