Upgrade 6.1.2 to 6.2.5 failed
Hello, I’m trying to upgrade my Seafile Server to 6.2.5 and get the these message:
[ERROR] Error:
ccnet is using MySQL
seafile is using SQLite3
seahub is using MySQL
Failed to upgrade your database
you may need to migrate one of your database from sqllite to mysql
https://manual.seafile.com/deploy/migrate_from_sqlite_to_mysql.html
No, this shouldn’t be a problem. But if you did this, you now have to export the seafile/seahub enviroment variables, because the config is overwritten.
It doesn’t work. The best is, set it new from the scratch. Delete all data and reinstall.
