Greetings all,
My first post on the forum. First and foremost, love the software! Hands down the best sync option I have ran across yet. I get the occasional sync conflicts to which I am not sure why, but it has worked out well.
So here’s where I am (was) at. I had Seafile server (running on Debian 9.4) v6.2.5 and recently my macOS client updated to 7.0.
I started noticing errors with messages like “Error indexing file /path/to/some/file”. I was syncronizing my VS Code config, and it was mainly in that. I read online somewhere where people said that they had issues like this, and updated server to 7.x and it fixed it.
So I upgraded to 7.0.4. I ran the upgrade/upgrade_6.2_6.3.sh first, it had some errors, and updated the seafile-server-latest link to 7.0.4. I went ahead and ran the upgrade/upgrade_6.3_7.0.sh file, and it too had some errors. I was able to start up fine however, and thought I’ll see how it goes.
Now it seems like I am getting the indexing error on pretty much any library I have. It also mentions something about checking permissions or to check if I am out of disk space. The permissions have always been run by the same user, so Im not sure how that could have changed, and I checked, I have over a half TB free of space, so that shouldnt be the issue.
So I guess I am writing asking about 1) could someone look at the attached upgrade outputs and give me some guidance (not worry about it or do this to fix it) and 2) how do we fix this darn index issues.
Thank you!
Sighs. I cant attach screen shots very easily here without breaking any rules or making this too convoluted. Going to try just posting some text. Hope it all makes sense wont be as “pretty” though.
root@server:/opt/seafile/seafile-server-7.0.4# upgrade/upgrade_6.2_6.3.sh
This script would upgrade your seafile server from 6.2 to 6.3
Press [ENTER] to contiune
[INFO] You are using MySQL
[INFO] updating ccnet database…
/opt/seafile/seafile-server-7.0.4/upgrade/db_update_helper.py:352: Warning: Table ‘LDAPConfig’ already exists
cursor.execute(sql)
[INFO] updating seafile database…
/opt/seafile/seafile-server-7.0.4/upgrade/db_update_helper.py:352: Warning: Table ‘SeafileConf’ already exists
cursor.execute(sql)
/opt/seafile/seafile-server-7.0.4/upgrade/db_update_helper.py:352: Warning: Table ‘RepoInfo’ already exists
cursor.execute(sql)
/opt/seafile/seafile-server-7.0.4/upgrade/db_update_helper.py:352: Warning: Table ‘organizations_orgmemberquota’ already exists
cursor.execute(sql)
Done
migrating avatars …
Done
updating /opt/seafile/seafile-server-latest symbolic link to /opt/seafile/seafile-server-7.0.4 …
Upgraded your seafile server successfully.
root@server:/opt/seafile/seafile-server-7.0.4# upgrade/upgrade_6.3_7.0.sh
This script would upgrade your seafile server from 6.3 to 7.0
[WARNING] Failed to execute sql: (1146, “Table ‘ledoktre-seahub-db.TotalStorageStat’ doesn’t exist”)
[WARNING] Failed to execute sql: (1146, “Table ‘ledoktre-seahub-db.FileOpsStat’ doesn’t exist”)
[WARNING] Failed to execute sql: (1146, “Table ‘ledoktre-seahub-db.UserActivityStat’ doesn’t exist”)
[WARNING] Failed to execute sql: (1051, “Unknown table ‘ledoktre-seahub-db.UserTrafficStat’”)
[WARNING] Failed to execute sql: (1091, “Can’t DROP ‘profile_profile_contact_email_0975e4bf_uniq’; check that column/key exists”)
Done
migrating avatars …
Done
