i want to upgrade my Seafile Server 11 Community Edition to Version 12.
But on Upgrading i run into following problems:
[21:14h][root@Seafile][:/opt/seafile/seafile-server-latest/upgrade]$ ./upgrade_11.0_12.0.sh
This script would upgrade your seafile server from 11.0 to 12.0
Press [ENTER] to contiuneUpdating seafile/seahub database …
[INFO] You are using MySQL
[INFO] updating seafile database…
[INFO] updating seafevents database…
[WARNING] Failed to execute sql: (1146, “Table ‘seahub-db.UserActivity’ doesn’t exist”)
[WARNING] Failed to execute sql: (1146, “Table ‘seahub-db.Activity’ doesn’t exist”)
[WARNING] Failed to execute sql: (1146, “Table ‘seahub-db.FileHistory’ doesn’t exist”)
[WARNING] Failed to execute sql: (1146, “Table ‘seahub-db.FileAudit’ doesn’t exist”)
[WARNING] Failed to execute sql: (1146, “Table ‘seahub-db.FileUpdate’ doesn’t exist”)
[WARNING] Failed to execute sql: (1146, “Table ‘seahub-db.PermAudit’ doesn’t exist”)
Donemigrating avatars …
Done
Later i receive this Problem, too:
[21:19h][root@Seafile][:/opt/seafile/seafile-server-latest]$ ./seahub.sh start
Cannot find JWT_PRIVATE_KEY value from environment, try to read .env file.
It’s the first time you start the seafile server. Now let’s create the admin account
What is the email for the admin account?
[ admin email ]
Seafile Server starts, and Seahub Server start also.
I see Login Webinterface, but on logging in, i receive an Website Error.
i would appreciate any ideas which help me tu upgrade my Seafile Server to Version 12 CE successfully.
thanks in advance
sourcedoctor
