Upgrade Seafile CE 5.0.3 to 5.1.3 Not Working
Hi:
I wonder if someone can suggest a solution.
I have Seafile running on a Windows Server 2008 R2 and it was working 100%
I upgraded to version 5.1.3 and followed the instructions to the letter.
Now I cant see any libraries and I get a red “Error” instead.
I can see the History and the download links but when I click it says “The page is not available due to a Server hicup”
If I create a new user it will not get a New Library either.
I am using SQlite db and I did not backed up the old db so now I am stuck.
Can someone help please. I have files I need to retrieve and I dont know how.
I will pay if neccesary for this issue to be sorted out.
Many thanks.
Shariff
Please check seahub_django_request.log.
Most likely adding the following line in seahub_settings.py will solve the problem:
TIME_ZONE = 'UTC'
That did the trick!
Amazing!
Something so simple.
Many Thanks
Shariff
