im running seafile on a FreeBSD server and just migrated from 9.x to 11.
Now i have a problem. Login works fine, but if i try to access Systemadmin/Users/LDAP or LDAP(imported) i get an “internal server error”
Even it is not noted in the upgrade manual i tried to remove the ldap entries in ccnet.conf, but this didn’t help, on the contrary, i couldn’t start the seahub server at all.
The seahub.log shows the following error when i try to access ladp or ldap(imported)
2024-01-14 11:30:38,960 [ERROR] seahub.api2.endpoints.admin.users:920 get Failed to query email_user object list from ccnet_db.
2024-01-14 11:30:38,961 [ERROR] django.request:224 log_response Internal Server Error: /api/v2.1/admin/ldap-users/
2024-01-14 11:30:40,811 [ERROR] seahub.api2.endpoints.admin.users:123 get_user_objs_from_ccnet Failed to query email_user object list from ccnet_db, error: (1064, “You have an error in your SQL syntax; check th
e manual that corresponds to your MySQL server version for the right syntax to use near ‘)’ at line 2”).
Thanks for any advice
Gav
