I just upgrade raspberry seafile server 6.3.4 to 7.0.4 and I get seafile database error
I have install certifi and idna.
Am I missing anything else? Please help
seafile.log
[08/12/19 14:34:15] http-server.c(175): fileserver: worker_threads = 10
[08/12/19 14:34:15] http-server.c(190): fileserver: fixed_block_size = 8388608
[08/12/19 14:34:15] http-server.c(205): fileserver: web_token_expire_time = 3600
[08/12/19 14:34:15] http-server.c(220): fileserver: max_indexing_threads = 1
[08/12/19 14:34:15] http-server.c(235): fileserver: max_index_processing_threads= 3
[08/12/19 14:34:15] http-server.c(257): fileserver: cluster_shared_temp_file_mode = 600
[08/12/2019 02:34:15 PM] …/common/mq-mgr.c(54): [mq client] mq cilent is started
[08/12/2019 02:34:15 PM] …/common/seaf-db.c(425): Error prepare statement SELECT r.repo_id, s.size, b.commit_id, v.repo_id, v.origin_repo, v.path, v.base_commit, fc.file_count, i.status FROM Repo r LEFT JOIN Branch b ON r.repo_id = b.repo_id LEFT JOIN RepoSize s ON r.repo_id = s.repo_id LEFT JOIN VirtualRepo v ON r.repo_id = v.repo_id LEFT JOIN RepoFileCount fc ON r.repo_id = fc.repo_id LEFT JOIN RepoInfo i on r.repo_id = i.repo_id WHERE r.repo_id = ? AND b.name = ‘master’: sqlite3_prepare_v2 failed: no such column: i.status.
[08/12/2019 02:34:15 PM] seafile-session.c(402): Failed to get system default repo. Create a new one.
[08/12/2019 02:34:16 PM] …/common/seaf-db.c(425): Error prepare statement SELECT r.repo_id, s.size, b.commit_id, v.repo_id, v.origin_repo, v.path, v.base_commit, fc.file_count, i.status FROM Repo r LEFT JOIN Branch b ON r.repo_id = b.repo_id LEFT JOIN RepoSize s ON r.repo_id = s.repo_id LEFT JOIN VirtualRepo v ON r.repo_id = v.repo_id LEFT JOIN RepoFileCount fc ON r.repo_id = fc.repo_id LEFT JOIN RepoInfo i on r.repo_id = i.repo_id WHERE r.repo_id = ? AND b.name = ‘master’: sqlite3_prepare_v2 failed: no such column: i.status.
[08/12/2019 02:34:16 PM] repo-op.c(644): Repo 59c7cb9d-a9cc-4286-bb94-b459dd4a5dbe doesn’t exist.
[08/12/2019 02:34:16 PM] seafile-session.c(365): Failed to add template file /media/sata/mycloud/seafile-data/library-template/seafile-tutorial.doc.
seafdav.log
[2019-08-12 14:34:21,785]: Init seahub database…
[2019-08-12 14:34:21,795]: Failed to init seahub db: No module named seahub_settings.
