Hi all,
I wand to use Enabling Https with Nginx
so successfully that but breaks CSS
this is error screen
I try delete cache server and chrome
rm -rf /tmp/seahub_cache/* and _Ctrl + Shift + R
and change https → http can’t see errer
no error
breaks css
this is my media file
and conf file
nginx.conf
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# server_names_hash_bucket_size 64;
# server_name_in_redirect off;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
access_log /var/log/nginx/access.log;
error_log /var/log/nginx/error.log;
# Gzip Settings
gzip on;
gzip_disable "msie6";
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript;
# Virtual Host Configs
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/sites-enabled/*;
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
seafile.conf
listen 80;
server_name 192.168.91.134;
listen 443;
ssl on;
ssl_certificate /home/ubuntu/seafile/seafile-pro-server-6.0.3/cacert.pem; # path to your cacert.pem
ssl_certificate_key /home/ubuntu/seafile/seafile-pro-server-6.0.3/privkey.pem; # path to your privkey.pem
server_tokens off;
fastcgi_pass 127.0.0.1:8000;
fastcgi_param HTTPS on;
fastcgi_read_timeout 36000;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
rewrite ^/media(.*)$ /media$1 break;
root /home/user/seafile/seafile-server-latest/seahub;
please check thank you.
