Very slow upload with webdav
I am using nautilus to mount seafile server via webdav. My upload speed is 3kB/sec which is unusable. I am using nginx for reverse proxy.
Nginx config file:
    listen 443 http2;
    ssl on;
    ssl_certificate /etc/letsencrypt/live/files.domain.com/fullchain.pem;        # path to your cacert.pem
    ssl_certificate_key /etc/letsencrypt/live/files.domain.com/privkey.pem;    # path to your privkey.pem
    include /etc/letsencrypt/options-ssl-nginx.conf;
server_name files.domain.com;
    server_tokens off;
        fastcgi_param   SERVER_PROTOCOL        $server_protocol;
        fastcgi_read_timeout 36000;
        proxy_read_timeout  36000s;
        proxy_send_timeout  36000s;
        root /var/www/files.domain.com/seafile-server-latest/seahub;
location /seafdav {
    fastcgi_pass    127.0.0.1:8080;
    proxy_request_buffering off;
have you tried another client like BitKinex (windows)? Only to check if the speed is the same.
It looks like it works fine from android. What could cause that behavior on nautilus?
Fixed! Installing davfs2 fixed the speed.
