Hallo,
einmal mit 30 Tagen, dann ohne Begrenzung
Ich habe ein Bib TEST erstellt. In dieser befindet sich eine ISO von ca. 300 MB. Auf der Consloe einen
du -sch *
304K 0868ba1b-61af-4622-a630-e16c6d6e0841
8.0K 997b9a41-cfa0-4c85-b0fd-e3fe30623b39
293M a2e014c9-9b25-4d84-852f-3fe8d255c45d
Jetzt lösche ich das ISO File
“342.01-desktop-win8-win7-winvista-64bit-international.exe ist gelöscht”
Dann gehe ich in den Papierkorb “Keine gelöschten Bibliotheken vorhanden”
Im Sysadmin
TEST 0 / 0 Bytes a2e014c9-9b25-4d84-852f-3fe8d255c45d info@grafjochen.de
Auf der Console
Danach
Stopping seafile server …
Done.
Stopping seahub …
Done.
sudo -u seafile /home/seafile/haiwen/seafile-server/seaf-gc.sh
Starting seafserv-gc, please wait …
[08/13/18 13:21:29] gc-core.c(440): GC version 1 repo TEST(a2e014c9-9b25-4d84-852f-3fe8d255c45d)
[08/13/18 13:21:29] gc-core.c(313): GC started. Total block number is 37.
[08/13/18 13:21:29] gc-core.c(46): GC index size is 1024 Byte.
[08/13/18 13:21:29] gc-core.c(327): Populating index.
[08/13/18 13:21:29] gc-core.c(181): Populating index for repo a2e014c9.
[08/13/18 13:21:29] gc-core.c(234): Traversed 3 commits, 37 blocks.
[08/13/18 13:21:29] gc-core.c(341): Scanning and deleting unused blocks.
[08/13/18 13:21:29] gc-core.c(364): GC finished. 37 blocks total, about 37 reachable blocks, 0 blocks are removed.
[08/13/18 13:21:29] gc-core.c(440): GC version 1 repo My Library Template(997b9a41-cfa0-4c85-b0fd-e3fe30623b39)
[08/13/18 13:21:29] gc-core.c(313): GC started. Total block number is 1.
[08/13/18 13:21:29] gc-core.c(181): Populating index for repo 997b9a41.
[08/13/18 13:21:29] gc-core.c(234): Traversed 2 commits, 1 blocks.
[08/13/18 13:21:29] gc-core.c(364): GC finished. 1 blocks total, about 1 reachable blocks, 0 blocks are removed.
[08/13/18 13:21:29] gc-core.c(440): GC version 1 repo Meine Bibliothek(0868ba1b-61af-4622-a630-e16c6d6e0841)
[08/13/18 13:21:29] gc-core.c(181): Populating index for repo 0868ba1b.
[08/13/18 13:21:29] gc-core.c(384): === Repos deleted by users ===
[08/13/18 13:21:29] gc-core.c(456): === GC is finished ===
sudo -u seafile /home/seafile/haiwen/seafile-server/seaf-gc.sh -r
[08/13/18 13:22:16] gc-core.c(384): === Repos deleted by users ===
seafserv-gc run done
Done.
[08/13/18 13:22:39] …/common/session.c(132): using config file /home/seafile/haiwen/conf/ccnet.conf
Starting seafile server, please wait …
Seafile server started
Done.
Seahub is started
Done.
Der Ornder in blocks ist immer noch
du -sch a2e014c9-9b25-4d84-852f-3fe8d255c45d
gross.
Das bringt mir leider nichts wenn ich die ganze Bib lösche “dann geht es”.
Ich kann ja nicht immer die ganze Bib löschen, damit der Speicher freigegeben wird.
Bin ich hier der einizge mit diesem Problem?
danke liebe grüsse
