Web_token_expire_time?
As default the web_token_expire_time is 3600s in seafile.conf.
That’s not so long if your uploading big files.
I want to change it to 7200s, and ofc I’ll do that in the seafile.conf file, but I also using NGINX so my guess is that I should change it in NGINX also?
Should I also change it in NGINX?
If I should change something in my NGINX config, what should I change?
Edit:
I’m running NGINX with HTTPS
NGINX don’t have anything with this. Just check your time in seafile config like manual saying.
Thanks…!
