What does 2FA apply to?
Will it only apply when signing in via web gui, app, client or even to seadrive and webdav?
Seahub: yes
App: yes
Client: yes
WebDAV: no (login without 2nd factor)
grafik
Thanks for clarifying and helping out.
Glad I could help.
Let me add two things:
  • API access isn’t protected by 2FA either.
  • If you want to enforce 2FA, it is recommended to disable WebDAV (it is recommended anyway, if you don’t use it. But with 2FA as a must, it becomes imperative.)
Please mark answer as solved if this is what you wanted to know.
They do have docs for API access if you have 2FA enabled https://download.seafile.com/published/web-api/home.md
If you have enabled two-factor authentication, you need to add 2FA header in HTTP when getting the access token:
curl -d “username=username@example.com&password=123456” -H 'X-SEAFILE-OTP: ’ https://cloud.seafile.com/api2/auth-token/
