Hi all,
I recently bought a raspberry pi 4 after using seafile on a raspberry pi 1st generation a few years ago. I used to have to install everything by hand but it looks like seafile has made quite some progress! Unfortunately I am out of touch and I am not sure anymore how I should install seafile on my raspberry?
Can I deploy seafile using docker? Something else I didn’t understand from the documentation: what do I need to install before I start the docker installation? I see that I need to populate the mysql fields in the configuration files - does this mean that I have to use MySQL as opposed to SQLite? I am not sure which dependencies I should install before I start following the “deploy with docker” documentation.
Sorry for these questions which might seem pretty stupid! I had never heard of docker before today.
Thanks,
Nico.
