Wrong storage size calculation
Hi
Unfortunately, we find out that the space used in the system administration panel under “Info” does not match the space actually used.
The customer receives the information “19.4GB”.
We have 24GB in our system:
[root@h01 seafile-data]# du -hs storage
24G storage
Since we distribute seafile pro and ce as shared solution to customers, a correct storage space calculation is indispensable. We limit the seafile instances with LVM and the customer must be able to rely on the display which size he uses.
It sounds very much like this case, which should already be fixed:
best regards,
Felix
19.4GB is how large his files are, but there are other components and the deleted files, if you haven’t run gc yet.
History is not part of the storage calculation.
